gabriels
2009-03-29 03:34:34
I believe my question may already have been answered in a previous post on this forum, but I didn't really understand the answer.
In Ableton, I want to be able to select all clips in order to make adjustments to some parameters in all of them at the same time.
I can do this in two ways:
1)Click and drag with the mouse over the clips displayed on the screen. They are selected in this way, and I can then change the settings I'm interested in.
or
2. Click on the clip at the lower left of the screen, then Shift-click on the clip at the upper right of the screen. This selects all samples in between.
Since I use a midi control surface to play Ableton, I don't have a mouse or a keyboard available...just lots of pots and buttons on the controller.
I've tried to use Bomes Classic in this way:
- Train Ableton (using map mode) so that when Bomes sends a keystroke (for example "x") Ableton selects the lower left clip, and when Bomes sends an "s" Ableton selects the upper right clip.
- Create a Bomes translator that sends "x Shift s".
This doesn't work. It seems that the Shift isn't latched on because I end up with the upper right clip is selected but not the entire range of clips.
Is there some way to latch the Shift sent by Bomes, so that it is still recognized as being pressed when Ableton receives the final "s"?
If Classic can't do this, would I be able to do it using Pro, and using the mouse function to send absolute x,y (lower left corner of screen), then click, then absolute x,y (upper right corner of screen). Would this be the equivalent of dragging over the range of clips?
Gabriel
or
Gabriel
