paul7622000
2009-04-10 09:28:09
I am using the Midi Mouse which can be found at: http://www.sweetwater.com and search midi mouse to know its features. Its basically has 128 patch programs and has 3 foot controller buttons which are:
UP button
Down button
Active/Search button
basically i click up it blinks on "01" then i stomp active and it goes into a solid LED light which means it sends that 01 Midi Patch message out.
Then i have my midi out of this mouse controller into the Midi IN of my Fast Track Pro
I am using Ableton Live 6. Now i was told my midi mouse just keeps on sending a note message thaT APPEARS in the ableton mapping as "PitchBend" and it wont allow me to assign unique Patch number out the 128 that are available in the midi mouse to each "Scene " in ableton. All i want to do is trigger with up and down buttons on my mid mouse to program change to increment or decrement to each scene that i choose. Now do i need the FCB1010 behringer or can i still use this midi mouse with Bomes. WHat would the incoming messages look like and the outgoing messages look like to have it control and FIre each seperate scene in Ableton?
Wish i could attach a manual of midi mouse to explain it better to you but here's my email to request it if needed. pdnmusic at gmail dot com
Meanwhile i loaded the original template http://www.bome.com/midi/translator/hel ... leton.html into my bomes. Although it seems like alot of messages programmed and not sure if thats going to work for my midi mouse or if i can just modify the template a bit.
UP button
Down button
