yvon
2009-04-15 01:57:02
ADDED COMMENT: how about the first message (instead of, 'Ex: lowest note on keyboard") Instead: have it be some pedal info first, and THEN the note on the keyboard that triggers the midi program change send message.
So: say, a switch or controller pedal that send some message which lets translator know that the NEXT note ON (or off?) message is to be translated to a program change. So by just hitting the footpedal/switch first would AFTER that allow every note on the keyboard to send a program change. (once per pedal/switch press of course)
The keyboard would have to go back to normal play after the program change obviously, so maybe it would have to be that: WHILE the switch/pedal was depressed or in the right position the keyboard became available to have a note trigger a program change.
This IS possible right.
---------- EARLIER text BELOW -------------
I can send any patch change by using a footpedal. So patch change 2 then 27 then 15. I am looking for a way to do this though not need to use the footpedal. By doing the change manually from the piano keyboard.
I though it might be possible to hold a note down and then hit a second note which calls the patch it's assigned to. Or ANYTHING similar.
For example:
1) hold the lowest note down on the piano keyboard.
2) WHILE it is held HIT another note.
3) This causes translator to send a program change.
Can ANYTHING like this be done? or some similar way to send any patch change and not have to do them sequentially, Don't want to have to have the patch desired IN any order. Just be able to jump to whatever patch is needed.
The idea is to NOT need a foot pedal to generate patch changes.
AND to be able to choose/jump-to whatever patch change is desired based on the SECOND note being hit while the first note is held down. (which tell translator to listen for second note about to come)
um, I think I said that a few ways, uh, the same way.
big thanks!
For example:
big thanks!
