DvlsAdvct
2009-04-21 21:00:28
Hi Guys
So Traktor has a function called soft takeover. For those that don't know, the basic idea is that by using Modifiers I can set the same knob (CC/channel number) to control separate functions independently. So, for example, I set one knob to control the Bass of Deck A and Deck C. When I activate it to control Deck A I set it to 70%. Then I activate it to control Deck C and turn it back to 20%. When I reset it to activate Deck A it isn't lined up anymore, obviously. The knob will be at 20% and Deck A will be at 70%. Soft Takeover forces Deck A's Bass to not move until the knob lines up with it. So, No matter what I do on my controller, Deck A's bass will not increase or decrease until I turn the knob to 70%.
I want to know how to do this in Bomes through preset switches. The incoming message will be the same, but the outgoing message to Traktor will be different. I figure if I output on global variables there has to be a way to have it work this way.
Traktor will only allow the soft takeover function to work if the incoming message is the same for both knobs (So I'd have to use Traktor's Modifiers, which I don't want to do) and since I'm using preset switches in Bomes so the knobs send on different MIDI channels, this is not possible.
I hope this makes sense (I know I have a tendency to make absolutely no sense on this forum).
