version 1.6.1 of Midi Translator only works on one MIDI device at a time, so it wouldn't be of much help.
However, version 1.7.0 supports any number of MIDI devices. We also make sure that if you connect multiple devices with the same name, they'll all show up in MT with different indexes appended to their names.
Further, MT 1.7.0 gives you "MIDI Port Aliases", i.e. you can define aliases "My NanoKontrol 1" and "My NanoKontrol 2". Now when defining the mappings, you can conveniently choose which MIDI port alias a given mapping applies to. It'll be easy to change the channel of one nano kontrol then, and to remap the entire thing, add more switchable presets, etc.
Then in the MIDI setup, you can select which of the two NanoKontrols corresponds to the aliases you created. Like that, you don't need to physically swap the devices, but you can just switch the alias definition.
Hope that makes any sense
PS: MT 1.7.0 is available for Windows, and in a beta version for OSX.
