DeRoc
2009-06-18 21:57:21
Hello all- I'm very impressed by the breadth of usefulness of this program.
I just purchased v1.7.0 (for WinXP) hoping it might have fixed this problem, but it still doesn't work for me. After hitting "apply" the Outgoing Action always shows "0"
At the end of a timer delay, I want to deactivate the preset using a number so I can freely reorder my presets without the need to rename anything inside the translators (I'm setting up quick program launches using a drum pad).
All the other "activate by" and "deactivate by" functions seem to work including activate-by-number; it's just the deactivate is not working.
Thanks for any input.
