DeRoc
2009-06-20 03:50:55
I just noticed that keystrokes aren't delivered to a secondary dialog box that opens after an Outgoing "Execute File" is run. It works fine if the launched program is started entirely with keystrokes, though.
For example, using only keystroke emulation, I open an envelope.doc mailer in MS Word using a text list of names and Word always opens a dialog box to ask if this is the correct list to use (don't ask why - my list is probably not exactly the correct format), and a second confirmation box after that.
I'm able to handle it with two keystrokes (a "Y"and "Enter") after a 3-second timer delay.
Now, trying to use the new "Execute File" function in Outgoing, those two keystrokes are not sent to the dialog popup boxes at all (I manually press "Y" and "Enter" to clear them) but are now sent to the document page itself. I think Word is remembering the keystrokes and inserts them.
Is this just the way it is when using Execute File? I hope I'm being clear on this.
tnx
tnx
