mike912
2009-06-30 13:39:35
I have setup the stanton preset to have all my own custom midi messages for live and deckadance with the scs3d, all was fine for the last 3 weeks since the beta release, then the other day it would not initiate virtual midi ports, when I tried to assign these ports they said "pending" in the status field.
looked through preferences to make sure virtual midi ports were enabled, they were not, I had never disabled them, they had disabled themselves somehow.
turned them on in prefs but still no go, just "pending" in the status field.
I restarted the software a few times and it didnt help, then I restarted the comp and it solved the issue, temporarily, but then it came back and happened again.
its also sending some strange errant midi messages from time to time, specifically and most often on the 4 corner buttons of the scs3m.
example-when I press the lower left corner button on the "vinyl" template its the play button for deckadance deck A, the upper left button is the rewind/jump to start button, the upper right is the tempo slave button.
each of these has a not on and note of message assigned
these arent the exact midi #'s but here's how it happens.
midi message 1 - 97 43 7f/87 43 00
midi message 2 - 97 22 7f/87 22 00
midi message 3 - 97 12 7f/87 12 00
so I press button 1 and the "43" on message goes out, I release my finger and the 43 off message goes out
then I press button 2 with the "22" on/off, the first message sent on contact will be the 43 on, when released it will send 22 off, then when pressed again it will be the 22 on and off as programed.
then I press button 3, and "22" on, then 12 off and so on, thats the pattern.
it has never happened with the lower right corner button.
this pattern appears and disappears from time to time across the corner buttons, the last previous message gets carried over to the new button for the first press, this will happen most often between the corner buttons
let me know if I made sense here guys
and please read this thread on the imageline forums because I really think that deckadance and bomes have some kind of issues
http://forum.image-line.com/viewtopic.php?t=36149
