gabriels
2009-07-07 11:05:19
I'd like to implement a program which would check to see if any one of the 96 faders on my midi control surface has moved, and if one has moved, do an action in Ableton Live. The MT program would also thin out the stream of messages going to Ableton (as I describe below) There's quite a lot going on in Ableton, and the CPU load is substantial already.
My question is whether there would be much of an additional load created by MT as it did the many evaluations of "flags" necessary to make such a MT program work (at least the way I designed it).
The alternative is to let each fader, as it is being moved, generate a continuous stream of midi CC messages, mixed in with a continuous stream of Mouse absolute positions, mouse button downs and mouse ups, mouse relative movements, and mouse button clicks generated by MT - all flowing to Ableton live.
I don't know how much of a CPU load this kind of midi message activity generates as it's received and processed in Ableton. But if I don't try to control the activity by using MT, this activity would only happen when I actually moved a fader or joystick. So there would be infrequent, but heavy bursts of midi activity when a fader (or faders) is/are moved...and then relative calm. This might be worse, than what I propose in the paragraph below.
By contrast, if I were to use MT to thin out the flow of such messages, MT itself would be continuously testing "flags" to see if any fader had moved. Once a fader moves, it's allowed to send a series of mouse commands to Ableton - but only once. Once the commands have been sent, a flag is set which prevents any additional mouse commands from being sent until the flag is reset. The CC messages are still sent since I am using them to move the virtual faders in Ableton. The flag is reset when any other fader moves.
This is a simplified explanation of what I'd be doing with MT. There are many translators doing other things at the same time, and even what I've described above is more intricate than I've said.
So the question is whether it would be worth it to spend the time to implement the program in MT. I'd hate to do it and then find that the CPU load caused by using MT in this fashion is more of a problem than the CPU load caused by having Ableton receive and process bursts of midi messages. Generally Ableton seems to be keeping up with these bursts, but I plan on increasing the number of samples being played and effects being used by Ableton, and that might leave it more vulnerable to increased CPU load.
Hope you can make sense of my rather convoluted explanation of my potential problems as I see them.
Gabriel
Gabriel
