Just download and open up the generic SCS.3d presets available from Stanton here;
http://forums.stantondj.com/viewtopic.php?f=25&t=24
They should work the same as the generic presets available via DaRouter. Check out the 'explanation' zip file for more info...
Jose... Are you telling me to use DaRouter, then you haven't understood my request... I will try to expalin this a bit clearer...
I have Bome MT Pro 1.7 on Windows and I like to play the SCS3 presets (*.bmtp) presets using Bome MT Pro instead of DaRouter. As I know I can only edit bmtp I am using “SSL Dual SCS.3d V1.00.bmtp” with Bome MT Pro 1.7.
In the situation below, only BOME MT is running and the computer is connected to 2 SCS3D's and two NanoPADs.
I like to know:
a. Which port aliases should I click to run the presets from Bome MT and I don't want DaRouter?
b. Which devices I should assign to these port aliases? Go to the link to see my Settings on BomeMT:
http://forums.stantondj.com/download/fi ... &mode=view
NOTE: I have installations of both DaRouter and Bome MT in my computer.
Please help me configure it. Thanks in Advance.
Diegie
