stillrocking
2009-09-16 16:04:37
Hi Folks
I have successfully used the midi out on my Zoom 4040 to change patches on a Bass POD while playing bass live.
I want to use it in a similar way to change patches (presets) on Guitar Box FX running on a laptop, while playing guitar live.
These 24 presets are stored as key presses – F1 to F12, and Ctrl+F1 to Ctrl+F12.
The laptop will have the Sonar SPS25 audio / midi / USB interface that came with Sonar Power Studio 6 attached, to take the other end of the midi cable coming from the Zoom 4040.
I am hoping that one or other version of Midi Translator will do the job. Which one will I need, and will I need an additional program like Midi Yoke?
Any advice would be appreciated ( total novice at midi )
Cheers
stillrocking
Info on effects program http://www.guitar-fxbox.com/
Info on Zoom midi implementation P26 of the manual – pdf doc at http://www.samsontech.com/products/prod ... &brandID=4
Cheers
stillrocking
