sekundenstil
2009-09-25 14:28:12
Hi to all,
I'm facing some issues while using the SHIFT key in combination with other keys. I want to remap some clips with other functionalities as clip start or stop. for that case I created some translators which enables some leds on the grid. now I want to use the stop triggers to switch between my own presets of functions. that should be done with SHIFT and STOP 1 or STOP 2 etc. buttons. I added a translator which says on pressing SHIFT and the STOP clip please activate a new preset. Now if I press SHIFT together with TOP 2 the second preset gets active and as long as I keep holding the SHIFT button the new configured LEDS are lit. Do I release the SHIFT button the LEDS go off.
For MIDI sequence I choose B0 xx pp 91 34 pp and that is working until I release the SHIFT button. Do I add the B0 xx pp behind both entries the MIDI mapping is not working any longer.
If I capture the sequence I get 8 messages if I press the SHIFT button then if I press the STOP button 91 34 pp I get 91 34 7F and 81 34 7F and if I release the SHIFT button only the 8 messages are displayed.
Does anybody know how to manage MIDI sequences including the SHIFT button?
Olli
Olli
