Converting midi msg from Roland sh-201 to Powercore Virus
Ultra404
2009-10-26 16:16:22
Hi all
This is my first post and I'm new to this nice program.
I need a help before buying it: my Sh-201 keyboard has plenty of pots but sends fixed midi messages. For example, the cutoff pot sends a 102 msg.
So said, I would like to control my vsti software on Cubase 5 and, mostly, my beloved Powercore Virus. As above, the Virus cutoff works if receives a 40 midi message. so the question is: can I convert the midi 102 msg of the roland (and then all the other pots) to the "40" midi msg needed from Virus?
Thank you
ruediger
2009-10-27 08:56:44
Midi Translator is exactly what you need!
Download the Trial version and check it out:
http://www.bome.com/midi/translator/download.html
For OS X, we recommend the beta 1.7.
Best regards,
Rüdi
Ultra404
2009-10-27 09:09:12
Oh well thank you
yes, but how? I mean there's no cc standard messages in MT... so how can I convert from 120 msg input to 40 output?
ruediger
2009-10-27 09:55:17
Midi Translator works hexadecimal based.
Try to capture the incoming MIDI message (120) with "Capture MIDI".
120 decimal = 78 hex.
Enter the same MIDI message as outgoing. Replace the 78 hex with 28:
40 decimal = 28 hex.
Cheers,
Rüdi
Ultra404
2009-10-27 10:21:42
Ok thanks, now I'm guessin' how to route this messages to the midi in of Cubase: Incoming tab is set as Keyb in and outgoing is MT virtual out. But now I can't play notes! Only midi commands translated from Mt go straight top the daw...
ruediger
2009-10-27 16:53:09
MIDI ports are exclusive, that means that you can open a port ony one time.
So, create a MIDI Route via the MIDI Router for routing the MIDI messages to cubase.
Cheers,
Rüdi
