two keys for incr up/down
beatskk
2009-11-11 18:41:33
title says it all. is it possible?
ruediger
2009-11-16 20:52:20
don't know what you want to do. Please explain it step by step...
RĂ¼di
2009-11-17 09:40:07
do you want to define two keys (on computer keyboard? or on MIDI keyboard?) that, when pressed, increase (or decrease, respectively) controller value, i.e. a fader or slider in a program?
beatskk
2009-11-18 05:23:34
hi,
yes, florian, that's exactly what i wanted. i should know better than to ask for help without properly describing my problem. won't happen again.
anyway, i think i have it down:
--------------- Preset fx select incr
Translator 0 :+
Options: swallow,2 rules
Incoming: MIDI 90 3D 7f
ga=ga+1
if ga>15 then ga=15
Outgoing: (none)
Translator 1 :New Translator
Incoming: MIDI 90 3D 7F
if ga!=15 then exit rules, skip Outgoing Action
ga=-1
Outgoing: MIDI B0 17 00
Translator 2 :New Translator
Options: swallow,1 rules
if ga!=0 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 05
Translator 3 :New Translator
if ga!=1 then exit rules, skip Outgoing Action
Outgoing: MIDI b0 17 0d
Translator 4 :New Translator
if ga!=2 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 16
Translator 5 :New Translator
if ga!=3 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 1e
Translator 6 :New Translator
if ga!=4 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 27
Translator 7 :New Translator
if ga!=5 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 2f
Translator 8 :New Translator
if ga!=6 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 38
Translator 9 :New Translator
if ga!=7 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 40
Translator 10 :New Translator
if ga!=8 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 48
Translator 11 :New Translator
if ga!=9 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 51
Translator 12 :New Translator
if ga!=10 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 5b
Translator 13 :New Translator
if ga!=11 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 64
Translator 14 :New Translator
if ga!=12 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 6c
Translator 15 :New Translator
if ga!=13 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 75
Translator 16 :New Translator
if ga!=14 then exit rules, skip Outgoing Action
Outgoing: MIDI B0 17 7f
Translator 17 :-
Incoming: MIDI 90 3C 7F
ga=ga-1
Outgoing: (none)
Translator 18 :New Translator
Translator 19 :New Translator
Outgoing: MIDI B0 17 06
Translator 20 :New Translator
Translator 21 :New Translator
Translator 22 :New Translator
Translator 23 :New Translator
Translator 24 :New Translator
Translator 25 :New Translator
Translator 26 :New Translator
Translator 27 :New Translator
Translator 28 :New Translator
Translator 29 :New Translator
Translator 30 :New Translator
Translator 31 :New Translator
Translator 32 :New Translator
Translator 33 :New Translator
ga=16
Translator 34 :reset timer
gb=1
Outgoing: One-shot timer "reset selector": 350 ms delay
Translator 35 :reset timer stop
Options: 1 rules
Incoming: MIDI 80 3C 7F
gb=0
Outgoing: (none)
Translator 36 :reset
Options: 2 rules
Incoming: On timer "reset selector"
if gb!=1 then exit rules, skip Outgoing Action
ga=0
the thing i've spend most time on was making it go from 0 to 127 and reverse.
the values are a bit strange, but they match the sixteen steps on an apc40 encoder (including zero), so i have a visual indicator from the knobs' led circle.
the last three translators are for resetting to zero if the decrease button is held for more than 350ms.
it's a lot of translators, is there a quicker way to do this? what if i wanted 128 steps?
regards
2009-11-23 09:54:03
yes, that's a good way to do it.
In order to optimize it, you can formulate the outgoing controller value as a mathematical expression:
Your translators #1 to #16 can be combined into one single translator. Use a rule to compute an outgoing value in the variable pp:
Translator: Send increased controller
Options: swallow
  pp=ga*8
  if pp>=128 then pp=127
Outgoing: MIDI B0 17 pp
The factor 8 determines the step size. E.g. if you use 6 instead of 8, it will increase slower.
As I understand it, you want the values to wrap around, i.e. if the maximum is reached, start over from the beginning. Then you can write translator #0 as such:
Translator 0 :+
Options: swallow
ga=ga+1
if ga>15 then ga=0
Outgoing: (none)
Of course you can also optimize the translators for decreasing the value. And I'd put the increase/decrease translators at the bottom so that they are executed AFTER sending the controller value.
Final preset:
Translator 0: Send increased controller
Options: swallow, NOT stop
  pp=ga*8
Translator 1: Send decreased controller
  pp=ga*8
Translator 2 :+
Options: swallow
ga=ga+1
if ga>15 then ga=0
Outgoing: (none)
Translator 3 :-
Options: swallow
ga=ga-1
if ga<0 then ga=15
Outgoing: (none)
Of course, leave the three timer translators as they are.
You could even combine Translators 0 and 1 into one, as they are identical except the incoming trigger. You could use "MIDI 90 qq 7F" as incoming, and check in the rules that qq is 3C or 3D. But probably that wouldn't optimize performance.
Hope that helps!
beatskk
2009-12-03 23:35:41
wow.
thanks man, that looks great. great support.
