garubi
2009-11-25 18:07:51
Hallo,
first time here
I'm trying to control ORGANized Trio (a VSTi Hammond Clone) with my Oberheim OB3^2.
The problems arises when I try to "map" the OB3 drawbars to command the "virtual" ones.
OB3 outputs the drawbars "level" as sysex string in this form:
FO 31 01 01 36 xx yy F7
where 36 is the value for the first drawbar and
xx & yy can be in the range of 00 00 to 01 7F (as I can read on the OB3 manual)
On the other side ORGANized Trio needs a Control Change message.
for the first drawbar the CC is #12
The problem is that the CC can only have the 0-127 range
I need a way to maybe "combine" and "reduce" the values coming from sysex to something valid in the CC range.
I read other post similar to this but, maybe because Exadecimal operation are far beyond my comprehension (after all I'm a musician...) I can't solve the problem.
Someone can help?
first time here
Someone can help?
