jeffreydean1999@yahoo.com
2009-12-03 04:08:26
Does anyone have any experience receiving midi messages from a midi foot controller and then forwarding them on to a midi input on a DMX Light Controller? I don't know how to format the midi message to the DMX controller for things like a scene change, bank, blackout or a chase.
Attigo
2009-12-06 07:24:34
Hi Jeffrey,
Midi Translator will be able to help you here. How do you connect your Foot Controller to your computer?
I should be able to help you once I know more about your setup...
Scott
2009-12-07 00:28:49
I use a MIDIMAN MIDISPORT 2x2
Attigo
2009-12-07 01:15:02
Ok, then it will be simple to connect your controllers through MT.
I am wondering if it is possible to take advantage of these internal controls on your DMX unit. If it is, then we will probably need a list of SYSEX commands that your unit recieves, which I have been looking for but I don't know what the exact product is. Can you point me to what your lighting controller is?
Scott
2009-12-07 02:17:08
The Light Controller is made by Irradiant model SRC-174
Attigo
2009-12-07 03:02:21
I can't find any data about the MIDI messages your controller sends/recieves, not even in the Manual.
Usually controllers recive the same MIDI messages that it sends, but I doubt when you change banks/modes that it will send any data out... Can you check?
Do you have any sources of the MIDI controllable functions of your own?
Scott
