Is there a quick way to turn off all presets?
gabriels
2009-12-28 01:20:03
Maybe this could be accomplished with preset switching, but I'm looking for an easier solution than figuring that out.
My controller is a bit noisy, and now and again spits out a Midi Command of some kind. It doesn't interfere with my intent for my system, but it does get in the way of debugging because the log window reacts to these commands and shifts the contents of the log window so I can't necessarily see the section of code I was inspecting.
If I could temporarily disable the inputs or outputs in some way, it would be helpful.
Gabriel
ruediger
2010-01-07 10:35:28
Hi Gabriel,
the only possibility to do that is Preset switching, sorry. We have added checkboxes on the log window (OS X) so that you can filter the log messages. Maybe that helps...
RĂ¼di
gabriels
2010-01-07 10:49:52
Rudi
I look forward to log filtering when it's implemented for Windows. ;-)
Gabriel
