UC-33e Mouseless Navigation Templates
Dolsign
2010-01-01 19:02:16
Hi
Can anybody tell me if the mac version of bome will work with these templates?
http://www.abletonlivedj.com/forum/view ... hp?t=18224
I've spoken to Patch and he said that he doesn't have a mac and said, "the main difference is that on the PC, there is a CTRL button, and on the Mac there is a COMMAND button. I'm not sure how Bomes for mac handles CTRL..."
kitlist:
Macbook and Macbook pro running ableton live 8
evolution uc33e
S4racen
2010-01-01 22:29:04
Hi Mate,
As your on a Mac it's simplistic to change any CTRL keyboard inputs to CMD ones, you simply enter into the rules section and then overtype...
Happy to help out if you need a hand, Patch is a top bloke!
Cheers
D
Dolsign
2010-01-02 01:58:07
okay that sounds pretty straight forward. Patch seems pretty cool and has been helpful with my enquiry, unfortunately he doesn't work with macs.
He did also mention about re-creating the translators in ControlAid and MidiStroke since bome for mac isn't free. I've downloaded these apps but I have no idea how to use them or what I'm supposed to do. If you can help out with that that would be great. I was under the assumption that this would make life easier but it seems to be pretty complicated
cheers
Dolsign
S4racen
2010-01-02 10:44:56
Sorry can't help you with control aid or midistroke, let me know when you've got patch's presets....
Use the trial of bomes with them first and we'll get them going....
CHeers
D
Dolsign
2010-01-03 00:06:49
okay cool, got the patches now dude...
S4racen
2010-01-03 09:31:56
Cool, add me on facebook.... http://www.facebook.com/darren.e.cowley ... ef=profile
This is so much easier doing it on chat......
Cheers
D
Dolsign
2010-01-03 11:47:20
cool adding you now dude
cheers
