WayneC
2010-01-05 07:06:13
I use an FCB1010 with Live, with Mackie Emulation. It works great, allowing me to cursur, launch, stop, start the looper, everything BUT delete, all hands free.
When I set up a delete preset on Bomes, it works! But when I try to assign non- Mackie Control midi notes to control the Live Looper, these no longer work. When Bomes Delete translator works, Mackie control also works. But no other midi assignments seem to work.
If I remove Bomes translator, my midi assignments for the Live Looper controls will work. I did verify that the FCB1010 is programmed correctly.
Arggh. I'm sure I'm not getting some part of the Input/Output in Live and or Bomes right.
Can somebody draw me a picture of how this needs to be hooked up?
Thanks for any help.
