Hi Valy20007,
To do this you will need to do something called 'upsampling'. What you really want is a whole number that both your 'ranges' divide into. Because MIDI doesn't support decimal numbers (therefore, neither does MT, it rounds up), this becomes a little tricky.
0-127 has 128 steps and
25-102 has 77 steps, so that number we are looking for is probably HUGE, so we will just settle for something close enough for this example:
128 x 3 = 384
384 / 77 = 4.99 (This is close enough to 5 so we shall use it.)
(I chose 3 because it was the first value I tested that came close a whole number)
To make the range of 128 into 77, we will take 128 and multiply it by 3, then divide that by 5 (4.99). This gives us 76.8, close enough to 77. To make this into the range you want, we just add 25 to that value, and there is (roughly) 25-102.
The Translator should look something like:
Translator 0: Change Range
Options: stop=false
Incoming: MIDI B0 01 oo
oo=oo*3
oo=oo/5
oo=oo+25
Outgoing: MIDI B0 01 oo
The higher the numbers you use, will make this new range more accurate, and if you can find a whole number that both 128 and 77 divide into then it should be perfect...
I hope you understand and this helps!
cheers,
Scott
