PM1978
2010-02-08 03:26:08
Drum Rack in Ableton is where I do alot of work.
I've built a custom Drumrack where each slot can hold up to 127 samples.
Drop Sampler in one of Drumracks slots, drop up to 127 samples in Sampler, use Abe's "Pitch" to scroll through the samples.
I use an MPD16, I'd like to assign the MPD's slider to control the pitch knob up and down.
Keep in mind, I just want the slider to control the pitch knob in the selected slot, not all of them simultaneously.
Luckily Abes has an option to select the last pad pressed on your controller which is gonna make this alot less painless.
I've seen this feature on the NativeKontrol APCseries software just for different parameters within the slots, this software uses MT runtime.
I've managed to do this with pads, but cannot get the slider to dual function up and down.I've learned how to map out alot of other features but have just spent my whole weekend trying to figure this out.
I tried classic version first and and kept getting incoming message FE??? Trial pro has gotten me comfortable as far as simple stuff like ARM, mute, transport, etc. I'm lost when it comes to rules.
Any ideas on how to get my slider doing this? Sorry for the noobness, and thanks.
