CountBlackula
2010-02-19 02:54:09
Basically,
I can open Bomes and create one translator and edit it, when i try to create a second it crashes. everytime!
I am not a fan of saving after each created translator and having to open the application again and repeat process!
Here is the error report... I have no f*cking idea what this all means, so please anyone, help me
Process: JavaApplicationStub [6284]
Path: /Applications/Bome's Midi Translator Pro.app/Contents/MacOS/JavaApplicationStub
Identifier: com.apple.javajdk16.Midi Translator Pro
Version: 1.6.1 (1.6.1)
Code Type: X86 (Native)
Parent Process: launchd [95]
PlugIn Path: /Applications/Bome's Midi Translator Pro.app/Contents/Resources/Java/libmt.so
PlugIn Identifier: libmt.so
PlugIn Version: ??? (???)
Date/Time: 2010-02-19 09:52:13.535 +0800
OS Version: Mac OS X 10.6.2 (10C540)
Report Version: 6
Interval Since Last Report: 1508844 sec
Crashes Since Last Report: 53
Per-App Interval Since Last Report: 43126 sec
Per-App Crashes Since Last Report: 9
Anonymous UUID: F08C07DA-3134-4DDE-8F0B-227066712796
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000802fe11d
Crashed Thread: 17 Java: AWT-EventQueue-0
Application Specific Information:
Java information:
Exception type: Bus Error (0xa) at pc=0x97c63a7b
Java VM: Java HotSpot(TM) Client VM (14.3-b01-101 mixed mode macosx-x86)
Current thread (0x02946c00): JavaThread "AWT-EventQueue-0" [_thread_in_native, id=-1314717696, stack(0xb1930000,0xb1a30000)]
Stack: [0xb1930000,0xb1a30000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j com.bome.mt.jni.TTransTimerAction.__getName(J)Ljava/lang/String;+0
j com.bome.mt.jni.TTransTimerAction.a()Ljava/lang/String;+8
j com.bome.mt.swing.a.a.A.a(Ljava/lang/Object;)V+10
j com.bome.mt.swing.a.a.b(Ljava/lang/Object;)V+6
j com.bome.mt.swing.a.c.b.a(Lcom/bome/mt/swing/t;)V+203
j com.bome.mt.swing.t.d()V+29
j com.bome.mt.swing.t.b()V+196
j com.bome.mt.swing.t.a()V+5
j com.bome.mt.swing.d.b.valueChanged(Ljavax/swing/event/ListSelectionEvent;)V+99
j javax.swing.DefaultListSelectionModel.fireValueChanged(IIZ)V+65
J javax.swing.DefaultListSelectionModel.fireValueChanged()V
j javax.swing.DefaultListSelectionModel.changeSelection(IIIIZ)V+92
j javax.swing.DefaultListSelectionModel.changeSelection(IIII)V+7
j javax.swing.DefaultListSelectionModel.setSelectionInterval(II)V+59
j com.bome.mt.swing.d.e.c(II)V+6
j com.bome.mt.swing.actions.f.a(Z)V+206
j com.bome.mt.swing.actions.f.actionPerformed(Ljava/awt/event/ActionEvent;)V+166
j javax.swing.AbstractButton.fireActionPerformed(Ljava/awt/event/ActionEvent;)V+84
j javax.swing.AbstractButton$Handler.actionPerformed(Ljava/awt/event/ActionEvent;)V+5
j javax.swing.DefaultButtonModel.fireActionPerformed(Ljava/awt/event/ActionEvent;)V+35
j javax.swing.DefaultButtonModel.setPressed(Z)V+117
j javax.swing.AbstractButton.doClick(I)V+98
j javax.swing.plaf.basic.BasicMenuItemUI.doClick(Ljavax/swing/MenuSelectionManager;)V+53
j javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Ljava/awt/event/MouseEvent;)V+62
j java.awt.AWTEventMulticaster.mouseReleased(Ljava/awt/event/MouseEvent;)V+8
j java.awt.Component.processMouseEvent(Ljava/awt/event/MouseEvent;)V+64
j javax.swing.JComponent.processMouseEvent(Ljava/awt/event/MouseEvent;)V+23
j java.awt.Component.processEvent(Ljava/awt/AWTEvent;)V+81
j java.awt.Container.processEvent(Ljava/awt/AWTEvent;)V+18
J java.awt.Component.dispatchEventImpl(Ljava/awt/AWTEvent;)V
J java.awt.Container.dispatchEventImpl(Ljava/awt/AWTEvent;)V
J java.awt.LightweightDispatcher.retargetMouseEvent(Ljava/awt/Component;ILjava/awt/event/MouseEvent;)V
j java.awt.LightweightDispatcher.processMouseEvent(Ljava/awt/event/MouseEvent;)Z+139
j java.awt.LightweightDispatcher.dispatchEvent(Ljava/awt/AWTEvent;)Z+50
j java.awt.Window.dispatchEventImpl(Ljava/awt/AWTEvent;)V+19
J java.awt.EventQueue.dispatchEvent(Ljava/awt/AWTEvent;)V
J java.awt.EventDispatchThread.pumpOneEventForFilters(I)Z
j java.awt.EventDispatchThread.pumpEventsForFilter(ILjava/awt/Conditional;Ljava/awt/EventFilter;)V+30
j java.awt.EventDispatchThread.pumpEventsForHierarchy(ILjava/awt/Conditional;Ljava/awt/Component;)V+11
j java.awt.EventDispatchThread.pumpEvents(ILjava/awt/Conditional;)V+4
j java.awt.EventDispatchThread.pumpEvents(Ljava/awt/Conditional;)V+3
j java.awt.EventDispatchThread.run()V+9
v ~StubRoutines::call_stub
Java Threads: ( => current thread )
0x02089c00 JavaThread "Engine Callback Poller" [_thread_blocked, id=-1309544448, stack(0xb1e1f000,0xb1f1f000)]
0x02089400 JavaThread "Event Monitor Poller" [_thread_blocked, id=-1310601216, stack(0xb1d1d000,0xb1e1d000)]
0x02800000 JavaThread "DestroyJavaVM" [_thread_blocked, id=-1332719616, stack(0xb0105000,0xb0905000)]
0x0294c000 JavaThread "TimerQueue" daemon [_thread_blocked, id=-1313660928, stack(0xb1a32000,0xb1b32000)]
=>0x02946c00 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=-1314717696, stack(0xb1930000,0xb1a30000)]
0x02921400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=-1317888000, stack(0xb162a000,0xb172a000)]
0x02052c00 JavaThread "AWT-Shutdown" [_thread_blocked, id=-1318981632, stack(0xb151f000,0xb161f000)]
0x02052400 JavaThread "AWT-AppKit" daemon [_thread_in_native, id=-1606068992, stack(0xbf800000,0xc0000000)]
0x0200cc00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1321095168, stack(0xb131b000,0xb141b000)]
0x0200b800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=-1322151936, stack(0xb1219000,0xb1319000)]
0x0200a800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1323208704, stack(0xb1117000,0xb1217000)]
0x02009800 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=-1324265472, stack(0xb1015000,0xb1115000)]
0x02003c00 JavaThread "Finalizer" daemon [_thread_blocked, id=-1325322240, stack(0xb0f13000,0xb1013000)]
0x028a8000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1326379008, stack(0xb0e11000,0xb0f11000)]
Other Threads:
0x028a6000 VMThread [stack: 0xb0d0f000,0xb0e0f000] [id=-1327435776]
0x0201e000 WatcherThread [stack: 0xb141d000,0xb151d000] [id=-1320038400]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 14336K, used 7907K [0x05010000, 0x06010000, 0x06010000)
eden space 12288K, 64% used [0x05010000, 0x057c8e30, 0x05c10000)
from space 2048K, 0% used [0x05e10000, 0x05e10000, 0x06010000)
to space 2048K, 0% used [0x05c10000, 0x05c10000, 0x05e10000)
concurrent mark-sweep generation total 49152K, used 3717K [0x06010000, 0x09010000, 0x09010000)
concurrent-mark-sweep perm gen total 20468K, used 12392K [0x09010000, 0x0a40d000, 0x0d010000)
Virtual Machine Arguments:
JVM Args: -Xbootclasspath/a:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources/LauncherSupport.jar -Dapple.awt.brushMetalLook=true -Dapple.laf.useScreenMenuBar=true -Djavaroot=/Applications/Bome's Midi Translator Pro.app/Contents/Resources/Java
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 3072M, Free = 708M
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x940408da mach_msg_trap + 10
1 libSystem.B.dylib 0x94041047 mach_msg + 68
2 com.apple.CoreFoundation 0x977bf77f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x977be864 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x977be691 CFRunLoopRunInMode + 97
5 com.apple.HIToolbox 0x91f6ff0c RunCurrentEventLoopInMode + 392
6 com.apple.HIToolbox 0x91f6fcc3 ReceiveNextEventCommon + 354
7 com.apple.HIToolbox 0x91f6fb48 BlockUntilNextEventMatchingListInMode + 81
8 com.apple.AppKit 0x92b0eac5 _DPSNextEvent + 847
9 com.apple.AppKit 0x92b0e306 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
10 com.apple.AppKit 0x92ad049f -[NSApplication run] + 821
11 libawt.jnilib 0x0d7e4dfa +[AWTStarter startAWT:] + 1706
12 libawt.jnilib 0x0d7a2727 -[CPerformer perform] + 243
13 com.apple.Foundation 0x91ac5ea8 __NSThreadPerformPerform + 705
14 com.apple.CoreFoundation 0x977c18cb __CFRunLoopDoSources0 + 1563
15 com.apple.CoreFoundation 0x977bf38f __CFRunLoopRun + 1071
16 com.apple.CoreFoundation 0x977be864 CFRunLoopRunSpecific + 452
17 com.apple.CoreFoundation 0x977be691 CFRunLoopRunInMode + 97
18 ...ple.JavaApplicationLauncher 0x0000758e startupJava(LauncherArgsStruct*) + 342
19 ...ple.JavaApplicationLauncher 0x000068cf launchJavaApplication + 1355
20 JavaApplicationStub 0x00001e8c 0x1000 + 3724
21 JavaApplicationStub 0x00001d0e 0x1000 + 3342
22 JavaApplicationStub 0x00001c35 0x1000 + 3125
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x940670ea kevent + 10
1 libSystem.B.dylib 0x94067804 _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x94066cc3 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x94066a68 _dispatch_worker_thread2 + 234
4 libSystem.B.dylib 0x940664f1 _pthread_wqthread + 390
5 libSystem.B.dylib 0x94066336 start_wqthread + 30
Thread 2:
2 libclient.dylib 0x0180ef23 JNI_CreateJavaVM_Impl + 57203
3 libclient.dylib 0x0180edab JNI_CreateJavaVM_Impl + 56827
4 libclient.dylib 0x0180e928 JNI_CreateJavaVM_Impl + 55672
5 libclient.dylib 0x0180e4a9 JNI_CreateJavaVM_Impl + 54521
6 libclient.dylib 0x018d6cd8 JVM_Write + 1592
7 libclient.dylib 0x018d67c7 JVM_Write + 295
8 ...ple.JavaApplicationLauncher 0x000084de startJavaApplication + 3726
9 ...ple.JavaApplicationLauncher 0x0000764e runJava(LauncherArgsStruct*) + 78
10 ...ple.JavaApplicationLauncher 0x000075f8 java_main_stub(void*) + 22
11 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
12 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 3: Java: Exception Handler Thread
2 libSystem.B.dylib 0x940ac5d8 mach_msg_server + 520
3 libclient.dylib 0x0180fe25 JNI_CreateJavaVM_Impl + 61045
4 libclient.dylib 0x0180fdca JNI_CreateJavaVM_Impl + 60954
5 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
6 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
7 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 4: Java: Gang worker#0 (Parallel GC Threads)
5 libclient.dylib 0x0180e588 JNI_CreateJavaVM_Impl + 54744
6 libclient.dylib 0x01824931 jio_vsnprintf + 321
7 libclient.dylib 0x0182486a jio_vsnprintf + 122
8 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
9 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
10 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 5: Java: Gang worker#1 (Parallel GC Threads)
Thread 6: Java: Concurrent Mark-Sweep GC Thread
2 libclient.dylib 0x0180f037 JNI_CreateJavaVM_Impl + 57479
3 libclient.dylib 0x0182bbb0 jio_vsnprintf + 29632
4 libclient.dylib 0x0180e9b7 JNI_CreateJavaVM_Impl + 55815
6 libclient.dylib 0x018e8b8c JVM_Available + 29852
7 libclient.dylib 0x0182b992 jio_vsnprintf + 29090
Thread 7: Java: VM Thread
6 libclient.dylib 0x018a3f5b JVM_Lseek + 142763
7 libclient.dylib 0x018a3c8a JVM_Lseek + 142042
Thread 8: Java: Reference Handler
4 libclient.dylib 0x018b8c95 JVM_MonitorWait + 5461
5 libclient.dylib 0x018b7bfe JVM_MonitorWait + 1214
6 libclient.dylib 0x018b787a JVM_MonitorWait + 314
7 ??? 0x0315badb 0 + 51755739
8 ??? 0x03003db1 0 + 50347441
9 ??? 0x03003db1 0 + 50347441
10 ??? 0x030012d3 0 + 50336467
11 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
12 libclient.dylib 0x018a5576 JVM_Lseek + 148422
13 libclient.dylib 0x018b711b JVM_InternString + 2123
14 libclient.dylib 0x018b6f8a JVM_InternString + 1722
15 libclient.dylib 0x018b6d74 JVM_InternString + 1188
16 libclient.dylib 0x018b680f JVM_StartThread + 2175
17 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
18 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
19 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 9: Java: Finalizer
9 ??? 0x03003f17 0 + 50347799
10 ??? 0x03003f17 0 + 50347799
11 ??? 0x030012d3 0 + 50336467
12 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
13 libclient.dylib 0x018a5576 JVM_Lseek + 148422
14 libclient.dylib 0x018b711b JVM_InternString + 2123
15 libclient.dylib 0x018b6f8a JVM_InternString + 1722
16 libclient.dylib 0x018b6d74 JVM_InternString + 1188
17 libclient.dylib 0x018b680f JVM_StartThread + 2175
18 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
19 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
20 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 10: Java: Surrogate Locker Thread (CMS)
6 libclient.dylib 0x018ce097 JVM_IsPrimitiveClass + 7639
7 libclient.dylib 0x018cdc11 JVM_IsPrimitiveClass + 6481
8 libclient.dylib 0x018b6d74 JVM_InternString + 1188
9 libclient.dylib 0x018b680f JVM_StartThread + 2175
10 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
Thread 11: Java: Signal Dispatcher
0 libSystem.B.dylib 0x94040916 semaphore_wait_trap + 10
1 libclient.dylib 0x018ceb5e JVM_IsPrimitiveClass + 10398
2 libclient.dylib 0x018ce92e JVM_IsPrimitiveClass + 9838
3 libclient.dylib 0x018b6d74 JVM_InternString + 1188
4 libclient.dylib 0x018b680f JVM_StartThread + 2175
Thread 12: Java: CompilerThread0
6 libclient.dylib 0x018cfec2 JVM_IsPrimitiveClass + 15362
7 libclient.dylib 0x018cfc9b JVM_IsPrimitiveClass + 14811
Thread 13: Java: Low Memory Detector
6 libclient.dylib 0x018d3e32 JVM_IsPrimitiveClass + 31602
7 libclient.dylib 0x018b6d74 JVM_InternString + 1188
8 libclient.dylib 0x018b680f JVM_StartThread + 2175
9 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
10 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
11 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 14: Java: VM Periodic Task Thread
3 libclient.dylib 0x018d510d JVM_IsPrimitiveClass + 36429
4 libclient.dylib 0x018d4cb3 JVM_IsPrimitiveClass + 35315
Thread 15: Java: AWT-Shutdown
10 ??? 0x0300428d 0 + 50348685
Thread 16: Java: Java2D Disposer
11 ??? 0x0300428d 0 + 50348685
12 ??? 0x030012d3 0 + 50336467
13 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
14 libclient.dylib 0x018a5576 JVM_Lseek + 148422
15 libclient.dylib 0x018b711b JVM_InternString + 2123
16 libclient.dylib 0x018b6f8a JVM_InternString + 1722
17 libclient.dylib 0x018b6d74 JVM_InternString + 1188
18 libclient.dylib 0x018b680f JVM_StartThread + 2175
19 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
20 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
21 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 17 Crashed: Java: AWT-EventQueue-0
0 libstdc++.6.dylib 0x97c63a7b std::string::_Rep::_M_grab(std::allocator<char> const&, std::allocator<char> const&) + 15
1 libstdc++.6.dylib 0x97c63b40 std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::string const&) + 36
2 libmt.so 0x1b154fb1 Java_com_bome_mt_jni_TTransTimerAction__1_1getName + 57
3 ??? 0x0300b839 0 + 50378809
4 ??? 0x03003f17 0 + 50347799
5 ??? 0x03003f17 0 + 50347799
6 ??? 0x03003db1 0 + 50347441
7 ??? 0x03003db1 0 + 50347441
8 ??? 0x0300428d 0 + 50348685
10 ??? 0x03003db1 0 + 50347441
11 ??? 0x03003db1 0 + 50347441
12 ??? 0x0300428d 0 + 50348685
13 ??? 0x03103910 0 + 51394832
14 ??? 0x03003db1 0 + 50347441
15 ??? 0x03003db1 0 + 50347441
16 ??? 0x03003db1 0 + 50347441
17 ??? 0x0300428d 0 + 50348685
18 ??? 0x03003db1 0 + 50347441
19 ??? 0x03003db1 0 + 50347441
20 ??? 0x0300428d 0 + 50348685
21 ??? 0x03003db1 0 + 50347441
22 ??? 0x0300428d 0 + 50348685
23 ??? 0x03003db1 0 + 50347441
24 ??? 0x0300428d 0 + 50348685
25 ??? 0x03003db1 0 + 50347441
26 ??? 0x03003db1 0 + 50347441
27 ??? 0x0300428d 0 + 50348685
28 ??? 0x0300428d 0 + 50348685
29 ??? 0x03003db1 0 + 50347441
30 ??? 0x03003db1 0 + 50347441
31 ??? 0x03003db1 0 + 50347441
32 ??? 0x031bc130 0 + 52150576
33 ??? 0x031971e0 0 + 51999200
34 ??? 0x0316eb5c 0 + 51833692
35 ??? 0x03003db1 0 + 50347441
36 ??? 0x03003fdd 0 + 50347997
37 ??? 0x031971c4 0 + 51999172
38 ??? 0x03003db1 0 + 50347441
39 ??? 0x03188a20 0 + 51939872
40 ??? 0x03165070 0 + 51794032
41 ??? 0x03003fdd 0 + 50347997
42 ??? 0x03003db1 0 + 50347441
43 ??? 0x03003db1 0 + 50347441
44 ??? 0x03003db1 0 + 50347441
45 ??? 0x03003db1 0 + 50347441
46 ??? 0x030012d3 0 + 50336467
47 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
48 libclient.dylib 0x018a5576 JVM_Lseek + 148422
49 libclient.dylib 0x018b711b JVM_InternString + 2123
50 libclient.dylib 0x018b6f8a JVM_InternString + 1722
51 libclient.dylib 0x018b6d74 JVM_InternString + 1188
52 libclient.dylib 0x018b680f JVM_StartThread + 2175
53 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
54 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
55 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 18: Java: TimerQueue
4 libclient.dylib 0x018b88a8 JVM_MonitorWait + 4456
9 ??? 0x0300428d 0 + 50348685
Thread 19:
2 com.apple.audio.midi.CoreMIDI 0x16d1bf31 XServerMachPort::ReceiveMessage(int&, void*, int&) + 155
3 com.apple.audio.midi.CoreMIDI 0x16d3a8fe MIDIProcess::RunMIDIInThread() + 150
4 com.apple.audio.midi.CoreMIDI 0x16d1d149 XThread::RunHelper(void*) + 17
5 com.apple.audio.midi.CoreMIDI 0x16d1cb16 CAPThread::Entry(CAPThread*) + 96
Thread 20:
0 libSystem.B.dylib 0x9404093a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x9406e445 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x9409d028 pthread_cond_timedwait_relative_np + 47
3 libmt.so 0x1b107766 bthread_cond_wait(bthread_cond_t*, int) + 112
4 libmt.so 0x1b1236fb Tr::TEvent::WaitMs(int) + 27
5 libmt.so 0x1b12b5c6 Tr::TRuntimeDispatcher::Execute() + 114
6 libmt.so 0x1b123c1f Tr::TThread::run(void*) + 23
7 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
8 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 21: Java: Event Monitor Poller
3 libclient.dylib 0x018d4fce JVM_IsPrimitiveClass + 36110
4 libclient.dylib 0x0191a223 JVM_Sleep + 403
5 ??? 0x03159f15 0 + 51748629
6 ??? 0x0315a6a8 0 + 51750568
7 ??? 0x03004280 0 + 50348672
8 ??? 0x030012d3 0 + 50336467
9 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
10 libclient.dylib 0x018a5576 JVM_Lseek + 148422
11 libclient.dylib 0x018b711b JVM_InternString + 2123
12 libclient.dylib 0x018b6f8a JVM_InternString + 1722
13 libclient.dylib 0x018b6d74 JVM_InternString + 1188
14 libclient.dylib 0x018b680f JVM_StartThread + 2175
15 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
16 libSystem.B.dylib 0x9406dfbd _pthread_start + 345
17 libSystem.B.dylib 0x9406de42 thread_start + 34
Thread 22: Java: Engine Callback Poller
Thread 17 crashed with X86 Thread State (32-bit):
eax: 0xb1a2f0be ebx: 0x1b154f86 ecx: 0x97c63a74 edx: 0x802fe115
edi: 0x02946d10 esi: 0xb1a2f0f8 ebp: 0xb1a2f098 esp: 0xb1a2f098
ss: 0x0000001f efl: 0x00010292 eip: 0x97c63a7b cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x802fe11d
Binary Images:
0x1000 - 0x1fff +JavaApplicationStub 1.6.1 (1.6.1) /Applications/Bome's Midi Translator Pro.app/Contents/MacOS/JavaApplicationStub
0x5000 - 0xfff7 com.apple.JavaApplicationLauncher 13.1.0 (13.1.0) <4AC23F10-15F8-A81C-A1A0-89FA16CC14FB> /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher
0x17000 - 0x1eff7 com.apple.JavaVM 13.1.0 (13.1.0) <2842C4EE-869D-81E6-E771-062F583A1044> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x75000 - 0x7dff7 libverify.dylib ??? (???) <0E0C6835-68C5-A72F-8CA0-77857B632513> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libverify.dylib
0x82000 - 0x89ff7 JavaNativeFoundation ??? (???) <1107BBC2-DFC1-CF1F-44EE-27F7D4349BE6> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x92000 - 0xafff7 libjava.jnilib ??? (???) <C4C57812-6A25-85AB-441B-DE1A71A8DF18> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjava.jnilib
0xcc000 - 0xd8ff7 libzip.jnilib ??? (???) <1317EACC-2494-70C3-4B43-FC9D04579EAF> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libzip.jnilib
0x1800000 - 0x1bf6fe7 libclient.dylib ??? (???) <6B8B4A7E-2844-3AD6-239E-122121D37485> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libclient.dylib
0x1cbb000 - 0x1cbcff7 liblauncher.jnilib ??? (???) <10117357-AD34-E263-4132-902438F8C368> /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/Resources/liblauncher.jnilib
0xd79c000 - 0xd95eff7 libawt.jnilib ??? (???) <FF31ED82-3BB5-A05D-3B83-35E11590E529> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libawt.jnilib
0xd9e6000 - 0xd9e9fe7 com.apple.java.JavaRuntimeSupport 13.1.0 (13.1.0) <70CFA5B6-4FFA-8EFB-E4CE-202B0B9A4DB6> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
0x15a99000 - 0x15a9cff7 liblaf.jnilib ??? (???) <373D235D-3372-814D-DDB5-11C1C750A48B> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/liblaf.jnilib
0x16d0c000 - 0x16d58fff com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x1a4f3000 - 0x1a556ff7 libfontmanager.jnilib ??? (???) <78446877-99AA-82F5-8509-0281A5740A47> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libfontmanager.jnilib
0x1ac19000 - 0x1ac39ff7 libdcpr.jnilib ??? (???) <51F632C6-87F3-5071-9545-896D34C353AB> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libdcpr.jnilib
0x1b051000 - 0x1b073ff7 libjpeg.jnilib ??? (???) <32233A65-09F0-434C-D616-64946CFEB3C0> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjpeg.jnilib
0x1b0d8000 - 0x1b0e5ff7 libnet.jnilib ??? (???) <E14CEE5F-42DC-9727-6A3E-FE25EAFFB423> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libnet.jnilib
0x1b0eb000 - 0x1b0eeff7 libnio.jnilib ??? (???) <6AE890EE-BB11-6931-EEBF-01AE9D682E3F> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libnio.jnilib
0x1b0f4000 - 0x1b2b4ffb +libmt.so ??? (???) <448D98C7-386E-4002-B9AB-7905DA538316> /Applications/Bome's Midi Translator Pro.app/Contents/Resources/Java/libmt.so
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0x90003000 - 0x9007dfef com.apple.audio.CoreAudio 3.2.2 (3.2.2) <1F97B48A-327B-89CC-7C01-3865179716E0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9007e000 - 0x90087ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x90088000 - 0x9008ffff com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x90130000 - 0x9044ffe7 com.apple.CoreServices.CarbonCore 861.2 (861.2) <A9077470-3786-09F2-E0C7-F082B7F97838> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x904cc000 - 0x904ecfe7 com.apple.opencl 12 (12) <2DB56F60-577B-6724-5708-7B082F62CC0F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x904ed000 - 0x9055cff7 libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x905ea000 - 0x906c4ff3 com.apple.DesktopServices 1.5.3 (1.5.3) <DA02AC94-7B0C-BD75-2305-C46A307A5FB0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x90809000 - 0x90889feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x908f9000 - 0x908fbff7 libRadiance.dylib ??? (???) <462903E2-2E77-FAE5-4ED6-829AAB1980A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x908fc000 - 0x9094dff7 com.apple.HIServices 1.8.0 (???) <B8EC13DB-A81A-91BF-8C82-66E840C64C91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9098d000 - 0x909f1ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x909f2000 - 0x90a3bfe7 libTIFF.dylib ??? (???) <5864AE5B-EAEB-F8B6-18FB-3D27B7895A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x90a55000 - 0x90b4bff7 libGLProgrammability.dylib ??? (???) <82D03736-D30C-C013-BBB1-20ED9687D47F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x90b60000 - 0x90b6efe7 libz.1.dylib ??? (???) <7B7A02AB-DA99-6180-880E-D28E4F9AA8EB> /usr/lib/libz.1.dylib
0x90c19000 - 0x90c1aff7 com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x90c1b000 - 0x913fe4b7 com.apple.CoreGraphics 1.536.12 (???) <263EB5FC-DEAD-7C5B-C486-EC86C173F952> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9150d000 - 0x9158fffb SecurityFoundation ??? (???) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9185b000 - 0x9186cff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <7A3862F7-3730-8F6E-A5DE-8E2CCEA979EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9186d000 - 0x9190afe3 com.apple.LaunchServices 362 (362) <8BE1C1A1-BF71-CE07-F3FB-6057D47AF461> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x91990000 - 0x919c1ff3 libTrueTypeScaler.dylib ??? (???) <6C8916A2-8F85-98E0-AAD5-0020C39C0FC9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x919c2000 - 0x91a12ff7 com.apple.framework.familycontrols 2.0 (2.0) <E6CAB425-3E40-65A3-0C23-150C26E9CBBF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x91a13000 - 0x91a4dffb libFontRegistry.dylib ??? (???) <72342297-E8D6-B071-A752-014134129282> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x91a5a000 - 0x91a65ff7 libCSync.A.dylib ??? (???) <9292E6E3-70C1-1DD7-4213-1044F0FA8381> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x91a99000 - 0x91d09ffb com.apple.Foundation 6.6.1 (751.14) <CD815A50-BB33-5AA1-DD73-A5B07D394DDA> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x91d0a000 - 0x91d50ff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x91d5f000 - 0x91f3aff3 libType1Scaler.dylib ??? (???) <F9FEA41E-F079-87B8-04A9-7FF3B2931B79> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x91f3b000 - 0x9225efef com.apple.HIToolbox 1.6.2 (???) <E02640B9-7BC3-A4B4-6202-9E4127DDFDD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x92508000 - 0x9286fff7 com.apple.QuartzCore 1.6.1 (227.8) <8B90AB08-46A4-1C5C-4E71-C6AB652477B9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x92870000 - 0x92882ff7 com.apple.MultitouchSupport.framework 204.9 (204.9) <B639F02B-33CC-150C-AE8C-1007EA7648F9> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x92ac6000 - 0x933a4ff7 com.apple.AppKit 6.6.3 (1038.25) <72A9AA47-8DCB-DB07-64F5-F837E98C62D8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x933a5000 - 0x933b2ff7 com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x93b09000 - 0x93b09ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x93e07000 - 0x93f33feb com.apple.audio.toolbox.AudioToolbox 1.6.2 (1.6.2) <9AAFDCBE-C68C-3BB3-8089-83CD2C0B4ED7> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93f34000 - 0x93f40ff7 libkxld.dylib ??? (???) <3D2C5BA3-6A8D-C861-B346-0E19942D9AF1> /usr/lib/system/libkxld.dylib
0x94040000 - 0x941e4feb libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
0x941e5000 - 0x941e6ff7 com.apple.audio.units.AudioUnit 1.6.2 (1.6.2) <845D5E0D-870D-B7E8-AAC5-8364AC341AA1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x941e7000 - 0x94369fe7 libicucore.A.dylib ??? (???) <2B0182F3-F459-B452-CC34-46FE73ADE348> /usr/lib/libicucore.A.dylib
0x9436a000 - 0x9436eff7 libGFXShared.dylib ??? (???) <79F4F60E-0A6D-CE9C-282E-FA85825449E3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9436f000 - 0x94372ff7 libCGXType.A.dylib ??? (???) <483FCF1C-066B-D210-7355-ABC48CA9DB2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x94373000 - 0x94373ff7 com.apple.Accelerate.vecLib 3.5 (vecLib 3.5) <3E039E14-2A15-56CC-0074-EE59F9FBB913> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x94374000 - 0x94427fff libFontParser.dylib ??? (???) <FAD5E96D-CF93-CC86-6B30-A6594B930772> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9445d000 - 0x9445dff7 com.apple.vecLib 3.5 (vecLib 3.5) <17BEEF92-DF30-CD52-FD65-0B7B43B93617> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9445e000 - 0x94464fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x94465000 - 0x944a9ff3 com.apple.coreui 2 (113) <D0FA9B36-3708-D5BF-0CC3-6CC1909BC8E6> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x944aa000 - 0x94563fe7 libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x945cc000 - 0x9460dff7 libRIP.A.dylib ??? (???) <9F0ECE75-1F03-60E4-E29C-136A27C13F2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9460e000 - 0x94636ff7 libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x94637000 - 0x94652ff7 libPng.dylib ??? (???) <3F8682CD-C05B-607D-96E7-767646C77DB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x949c8000 - 0x94a22ff7 com.apple.framework.IOKit 2.0 (???) <1BE07087-27D5-0E62-F06B-007C2BED4073> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x94a23000 - 0x94b51fe7 com.apple.CoreData 102.1 (250) <F33FF4A1-D7F9-4F6D-3153-E5F2588479EB> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x94b52000 - 0x94b87ff7 libGLImage.dylib ??? (???) <A6007BF7-BF3C-96DC-C435-849C6B88C58A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x94c72000 - 0x94c72ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x94c73000 - 0x94e2ffef com.apple.ImageIO.framework 3.0.1 (3.0.1) <598CF4F9-7542-E1A7-26D2-584933497A2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x94e30000 - 0x94e34ff7 IOSurface ??? (???) <C11D3FF3-EB51-A07D-EF24-9C2004115724> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x94e8b000 - 0x94f23fe7 edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x94f24000 - 0x94f74fe7 libGLU.dylib ??? (???) <659ADCA2-10EC-59BD-1B0A-4928A965F1D1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x94f75000 - 0x94f8dff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x94f95000 - 0x953caff7 libLAPACK.dylib ??? (???) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x953cb000 - 0x954ccfe7 libxml2.2.dylib ??? (???) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
0x9553e000 - 0x95552ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9574b000 - 0x957dcfe7 com.apple.print.framework.PrintCore 6.1 (312.3) <6D4322AF-703C-CC19-77B4-53E6D3BB18D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x957dd000 - 0x95879fe7 com.apple.ApplicationServices.ATS 4.1 (???) <EA26375D-8276-9671-645D-D28CAEC95292> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x958ab000 - 0x958c7fe3 com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x958e6000 - 0x958e9ff7 libCoreVMClient.dylib ??? (???) <A89D7A78-8FB0-2BDF-30DB-A35E04A6186B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x958ea000 - 0x958eaff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x959c7000 - 0x959dcfff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x959dd000 - 0x95beffef com.apple.RawCamera.bundle 2.2.2 (509) <E9DB0901-7FF3-881F-71AF-59984FCB3221> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x95f90000 - 0x95fd3ff7 com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x96a00000 - 0x96aadfe7 libobjc.A.dylib ??? (???) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
0x96aae000 - 0x96abbff7 com.apple.opengl 1.6.5 (1.6.5) <0AE8B897-8A80-2C14-D6FC-DC21AC423234> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x96abc000 - 0x96d1efe7 com.apple.security 6.1.1 (37594) <9AA7D9BF-852F-111F-68AD-65DD760D4DF3> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x96d1f000 - 0x96dc6fe7 com.apple.CFNetwork 454.5 (454.5) <A7E78E62-0C59-CE57-73D2-C4E60527781C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x96dc7000 - 0x96dccff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x96dcd000 - 0x96dedfe7 libresolv.9.dylib ??? (???) <A48921CB-3FA7-3071-AF9C-2D86FB493A3A> /usr/lib/libresolv.9.dylib
0x96dee000 - 0x96df0ff7 com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x96df1000 - 0x96dfbffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x96dfc000 - 0x96e10fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x96e11000 - 0x96e11ff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x96e12000 - 0x96ebaffb com.apple.QD 3.33 (???) <196CDBA6-5B87-2767-DD57-082D71B0A5C7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x97198000 - 0x9719bffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9719c000 - 0x971acff7 libsasl2.2.dylib ??? (???) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x971ad000 - 0x971b7fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x97264000 - 0x97341ff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x97342000 - 0x97366ff7 libJPEG.dylib ??? (???) <649E1974-A527-AC0B-B3F4-B4DC30484070> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x97367000 - 0x9736bff7 libGIF.dylib ??? (???) <83FB0DCC-355F-A930-E570-0BD95086CC59> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9736c000 - 0x97782ff7 libBLAS.dylib ??? (???) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x97783000 - 0x978fafef com.apple.CoreFoundation 6.6.1 (550.13) <AE9FC6F7-F0B2-DE58-759E-7DB89C021A46> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x978fb000 - 0x97938ff7 com.apple.SystemConfiguration 1.10.1 (1.10.1) <BA676C76-6AAD-F630-626D-B9248535294D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x97939000 - 0x97986feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x979fb000 - 0x97a2eff7 com.apple.AE 496.1 (496.1) <1AC75AE2-AF94-2458-0B94-C3BB0115BA4B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x97a2f000 - 0x97a55fff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x97a6f000 - 0x97acffe7 com.apple.CoreText 3.1.0 (???) <79FD1B5C-2F93-4C5D-B07B-4DD9088E67DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x97b19000 - 0x97b38fe3 libexpat.1.dylib ??? (???) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x97be8000 - 0x97bf2ff7 libGL.dylib ??? (???) <76A207FE-889A-CF1B-AF9A-795EEE5A463E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x97c33000 - 0x97c9dfe7 libstdc++.6.dylib ??? (???) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x97cd0000 - 0x97d7eff3 com.apple.ink.framework 1.3.1 (105) <CA3FBDC3-4BBA-7BD9-0777-A7B0751292CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x97d82000 - 0x97dc6fe7 com.apple.Metadata 10.6.2 (507.4) <DBCBAE7D-7B34-7806-C0B9-1E6E6D45562F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x98dc5000 - 0x98de7fef com.apple.DirectoryService.Framework 3.6 (621.1) <3ED4949F-9604-C109-6586-5CE5F421182B> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x98e22000 - 0x98ed1ff3 com.apple.ColorSync 4.6.2 (4.6.2) <F3F097AC-FDB7-3357-C64F-E28BECF4C15F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x98eea000 - 0x98f2cfe7 libvDSP.dylib ??? (???) <8F8FFFB3-81E3-2969-5688-D5B0979182E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x98f75000 - 0x98f78fe7 libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x990e3000 - 0x990e3ff7 com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x99106000 - 0x9913bff7 libcups.2.dylib ??? (???) <AFDC4D3C-0FF4-D459-B26C-4BA1093F9142> /usr/lib/libcups.2.dylib
0x9918c000 - 0x99290fe7 libcrypto.0.9.8.dylib ??? (???) <2E58547A-91CC-4C1A-9FCC-DA7515FDB68A> /usr/lib/libcrypto.0.9.8.dylib
0x99309000 - 0x99309ff7 com.apple.Accelerate 1.5 (Accelerate 1.5) <F642E7A0-3720-FA19-0190-E6DBD9EF2D9B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x993bc000 - 0x993daff7 com.apple.CoreVideo 1.6.0 (43.1) <1FB01BE0-B013-AE86-A063-481BB547D2F5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x993db000 - 0x994a5fef com.apple.CoreServices.OSServices 352 (352) <D9F21CA4-EED0-705F-8F3C-F1322D114B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
Model: MacBookPro3,1, BootROM MBP31.0070.B02, 2 processors, Intel Core 2 Duo, 2.2 GHz, 3 GB, SMC 1.16f11
Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 128 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), Atheros 5416: 2.0.19.8
Bluetooth: Version 2.2.4f3, 2 service, 1 devices, 3 incoming serial ports
Network Service: Built-in Ethernet, Ethernet, en0
Network Service: Built-in FireWire, FireWire, fw0
PCI Card: pci168c,24, sppci_othernetwork, PCI Slot 5
Serial ATA Device: FUJITSU MHW2120BH, 111.79 GB
Parallel ATA Device: HL-DT-ST DVDRW GSA-S10N, 516.5 MB
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd400000
USB Device: iPhone, 0x05ac (Apple Inc.), 0x1294, 0xfa200000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x021a, 0x5d200000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000
USB Device: Microsoft Notebook Optical Mouse with Tilt Wheel, 0x045e (Microsoft Corporation), 0x00d2, 0x1d100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x1a100000
