JohnnyCache
2010-02-20 02:07:32
Im trying to use the SCS.3 system [two scs.3d's and one scs.3m] with DjDecks.
The new version of DjDecks seems to include support for the scs.3d, but not the mixer. Also, it only seems to support only one deck, but that might be me setting it up incorrectly..
I can use the learn midi function in djdecks to map the controls manually.. but im having trouble enabling the entire system via the presets in DaRouter. The only preset so far that lets me use all the devices simultaniously is the "SCS3 System Traktor LE v1.00" but even that preset isnt perfect since the deck button is disabled and the gain and pitch functions dont quite work..
Are there any presets for bome's midi translator that just enable all functions so you can map them in your software manually?
Thanks for the info.
