meneldor
2010-02-23 21:07:42
Hi!
I have previously purchased the MTplayer through nativeKONTROL, and now I need a qwerty-to-MIDI translator. Could I use MTplayer for this, with a custom preset or something? or do I need the full version of the Bome midi translator?
//J
Attigo
2010-02-24 00:16:09
Hi meneldor,
If somebody has already made a preset that does this, then you will be able to use MTplayer, otherwise you will have to get MT and make it yourself. I don't know of anybody that has done this, but I know a few different DAWs support a qwerty keyboard 'in' as a MIDI keyboard. What is it you want to do?
Scott
meneldor
2010-02-24 08:43:25
I wanna use a qwerty keyboard to input MIDI messages to Serato. simple really.
Is there a config repository or something like that any place?
Attigo
2010-02-24 16:49:39
I'm not sure, but are you aware of the key-shortcuts in Serato? They are very handy...
Scott
meneldor
2010-02-24 19:49:56
yeah, I use them a lot. but I'm modding a keypad for serato use, so I need to change the configuration. And you can't change the keyboard shortcuts in Serato, plus some of the stuff I wanna do isn't covered by shortcuts, gotta do it in midi.
Does anyone know of any places that might have something I could use?
Or if MT is out of the question, does anyone know of a free/cheap program (MAC) that can convert qwerty to MIDI?
Attigo
2010-02-24 21:14:44
I think MT is your only option, the only software I know of that can do this. I can help you write a preset if you need?
Scott
Attigo
2010-02-24 21:41:37
Yo will need MT to make a full preset, and then you will be able to run it in MT Player...
Scott
meneldor
2010-02-24 21:48:25
rats.
I assume no one wants to write the whole thing for me, so I'm shit outta luck.
thanks anyways.
Attigo
2010-02-24 22:24:13
It's easy enough to do though buddy, and once you get your head round MT, you will realize it is def worth the money...
Scott
S4racen
2010-02-24 23:07:49
Best investment i've ever made...!
Cheers
D
