OSX Beta Program settings never saved
black_shades
2010-03-10 12:58:39
If I setup a program setting of 'do not show splash screen' for instance, the next time I reload it forgets that I set that.
It also copies the default presets every time as if, I'm running for the 1st time.
2010-03-30 17:01:18
Hi, your installation seems to have a problem saving the settings file. Normally, it's "~/.Bome/Bome's Midi Translator Pro.bmts" .
Can you please:
- fully delete your current version of Bome's Midi Translator
- install beta 1.7.0 beta 6
Also, if that doesn't help, you may either delete or check write permissions of the .bmts file.
Thanks and best regards,
black_shades
2010-03-30 17:48:54
Thanks I installed the latest beta and it fixed the issue
