ipomea
2010-03-16 12:51:42
Hi
I want to use KP3 touch pad to control various effects or group of effects in Ableton (Windows XP). Precisely, I want to use Bome to change KP3's XY touch pad CC numbers by triggering its program memory buttons (8 buttons on the top of KP3). I never used Bome, so my knowledge is very limited, and it could take lot of time, readings and manuals before make them work. So, I would appreciate it if anybody has some starting suggestions and tips, or maybe some presets for this combination. Or, is t possible to buy mentioned presets? Firstly, I want to test this on trial version, then if it works fine and if it is not too complicated, Im planning to buy software.
thank you very much
thank you very much
