babar69
2010-03-31 14:15:20
Hello,
first many thanks to be able to use this efficient program on stage. Less and less wies, more and more combinaisons with sound ,lights and video, it's great...
But concerning my midi vibes or other percussive piezoelectric triggered instruments, it's an old story, which slowly progress
So As i'm using differents inetrfacew which send, some 90 notes On and 80 notes Off, others 90 00 as note off, etc ...
I wrote different programs which swallow the notes off, let run the note On during a timer length, to be able to hear something better than a short 12 miliseconds "plock" LOL
My pb is when i use a global variable to set the time lengths to be able to program it for all translators and notes scales. It doesn't work, the global value is not taken in consideration.
To be more precise, if i give for , let's say G9 global variable the value of 200 msec, first it works, but when i want to make some dynamic changes ( with a pedal which send Control value assigned to this global variable, to change the timer lenght, and the note release) it's not active.
By the way, what is the way to erase all global variables. If i make some modifications, re run the program let old values in the global variables... I have to quit the program and run it again.
( yes maybe all this comes from my Fxxxxxxxx computer ? but it's the same on 2 other's PC)
Is there now a manual ( I think florain is gonna kill me, cause iI apologize not to read all the forum...NOOOOOOOOOOOOOOOOOOOOOOOO TIMEEEEEEEEEEEEEEEEEEEEEEE ):)
and the syntax to program the classic "For Next" and "if X>y AND Z<u" conditions ?
Anyway, this program is a real swiss knife !
Fabrice
Fabrice
