koots55
2010-04-16 10:51:47
Hi, I just got MT today and it crashes repeatedly. It worked a long time ago when I tested the program on a PC, but now I am using a MAC 10.6.3 Snow Leopard. I assume the reason this is happening is because I have Snow Leopard. But basically around %75 pf the times I try to make a new translator it crashes and says "Midi Translator Pro quit unexpectedly while using the libmt.so plugin." This is really annoying seeing how I have to make alot of translators but have to reopen the program every time I want to make one.
Here is the report:
Process: JavaApplicationStub [3705]
Path: /Applications/Bome's Midi Translator Pro.app/Contents/MacOS/JavaApplicationStub
Identifier: com.apple.javajdk16.Midi Translator Pro
Version: 1.6.1 (1.6.1)
Code Type: X86 (Native)
Parent Process: launchd [77]
PlugIn Path: /Applications/Bome's Midi Translator Pro.app/Contents/Resources/Java/libmt.so
PlugIn Identifier: libmt.so
PlugIn Version: ??? (???)
Date/Time: 2010-04-16 03:46:14.440 -0500
OS Version: Mac OS X 10.6.3 (10D573)
Report Version: 6
Interval Since Last Report: 14996 sec
Crashes Since Last Report: 6
Per-App Interval Since Last Report: 1602 sec
Per-App Crashes Since Last Report: 6
Anonymous UUID: 57CB36F5-88EB-47BF-9E31-D2EA886BD050
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000fffffff4
Crashed Thread: 17 Java: AWT-EventQueue-0
Application Specific Information:
Java information:
Exception type: Bus Error (0xa) at pc=0x239d9efe
Java VM: Java HotSpot(TM) Client VM (14.3-b01-101 mixed mode macosx-x86)
Current thread (0x020dbc00): JavaThread "AWT-EventQueue-0" [_thread_in_native, id=-1315774464, stack(0xb182e000,0xb192e000)]
Stack: [0xb182e000,0xb192e000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j com.bome.mt.jni.TTransMidiAction.__getMidiString(J)Ljava/lang/String;+0
j com.bome.mt.jni.TTransMidiAction.b()Ljava/lang/String;+8
j com.bome.mt.swing.a.a.U.a(Ljava/lang/Object;)V+10
j com.bome.mt.swing.a.a.b(Ljava/lang/Object;)V+6
j com.bome.mt.swing.a.c.n.a(Lcom/bome/mt/swing/t;)V+135
j com.bome.mt.swing.t.d()V+29
j com.bome.mt.swing.t.b()V+196
j com.bome.mt.swing.t.a()V+5
j com.bome.mt.swing.d.b.valueChanged(Ljavax/swing/event/ListSelectionEvent;)V+99
j javax.swing.DefaultListSelectionModel.fireValueChanged(IIZ)V+65
J javax.swing.DefaultListSelectionModel.fireValueChanged()V
j javax.swing.DefaultListSelectionModel.changeSelection(IIIIZ)V+92
j javax.swing.DefaultListSelectionModel.changeSelection(IIII)V+7
j javax.swing.DefaultListSelectionModel.setSelectionInterval(II)V+59
j com.bome.mt.swing.d.e.c(II)V+6
j com.bome.mt.swing.d.d.a()V+109
j com.bome.mt.swing.actions.f.a()V+3
j com.bome.mt.swing.actions.f.actionPerformed(Ljava/awt/event/ActionEvent;)V+116
j javax.swing.AbstractButton.fireActionPerformed(Ljava/awt/event/ActionEvent;)V+84
j javax.swing.AbstractButton$Handler.actionPerformed(Ljava/awt/event/ActionEvent;)V+5
j javax.swing.DefaultButtonModel.fireActionPerformed(Ljava/awt/event/ActionEvent;)V+35
j javax.swing.DefaultButtonModel.setPressed(Z)V+117
j javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Ljava/awt/event/MouseEvent;)V+35
j java.awt.AWTEventMulticaster.mouseReleased(Ljava/awt/event/MouseEvent;)V+8
j java.awt.Component.processMouseEvent(Ljava/awt/event/MouseEvent;)V+64
j javax.swing.JComponent.processMouseEvent(Ljava/awt/event/MouseEvent;)V+23
j java.awt.Component.processEvent(Ljava/awt/AWTEvent;)V+81
j java.awt.Container.processEvent(Ljava/awt/AWTEvent;)V+18
j java.awt.Component.dispatchEventImpl(Ljava/awt/AWTEvent;)V+566
J java.awt.Container.dispatchEventImpl(Ljava/awt/AWTEvent;)V
J java.awt.LightweightDispatcher.retargetMouseEvent(Ljava/awt/Component;ILjava/awt/event/MouseEvent;)V
j java.awt.LightweightDispatcher.processMouseEvent(Ljava/awt/event/MouseEvent;)Z+139
j java.awt.LightweightDispatcher.dispatchEvent(Ljava/awt/AWTEvent;)Z+50
j java.awt.Window.dispatchEventImpl(Ljava/awt/AWTEvent;)V+19
J java.awt.EventQueue.dispatchEvent(Ljava/awt/AWTEvent;)V
J java.awt.EventDispatchThread.pumpOneEventForFilters(I)Z
j java.awt.EventDispatchThread.pumpEventsForFilter(ILjava/awt/Conditional;Ljava/awt/EventFilter;)V+30
j java.awt.EventDispatchThread.pumpEventsForHierarchy(ILjava/awt/Conditional;Ljava/awt/Component;)V+11
j java.awt.EventDispatchThread.pumpEvents(ILjava/awt/Conditional;)V+4
j java.awt.EventDispatchThread.pumpEvents(Ljava/awt/Conditional;)V+3
j java.awt.EventDispatchThread.run()V+9
v ~StubRoutines::call_stub
Java Threads: ( => current thread )
0x0d91ec00 JavaThread "Engine Callback Poller" [_thread_blocked, id=-1309949952, stack(0xb1dbc000,0xb1ebc000)]
0x0d91e400 JavaThread "Event Monitor Poller" [_thread_blocked, id=-1311006720, stack(0xb1cba000,0xb1dba000)]
0x0d933400 JavaThread "DestroyJavaVM" [_thread_blocked, id=-1332719616, stack(0xb0105000,0xb0905000)]
0x0d932c00 JavaThread "TimerQueue" daemon [_thread_blocked, id=-1314717696, stack(0xb1930000,0xb1a30000)]
=>0x020dbc00 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=-1315774464, stack(0xb182e000,0xb192e000)]
0x020e5000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=-1317888000, stack(0xb162a000,0xb172a000)]
0x020de000 JavaThread "AWT-Shutdown" [_thread_blocked, id=-1318981632, stack(0xb151f000,0xb161f000)]
0x0d8a2c00 JavaThread "AWT-AppKit" daemon [_thread_in_native, id=-1603558176, stack(0xbf800000,0xc0000000)]
0x0d80d800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1321095168, stack(0xb131b000,0xb141b000)]
0x0d80cc00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=-1322151936, stack(0xb1219000,0xb1319000)]
0x0d80bc00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1323208704, stack(0xb1117000,0xb1217000)]
0x0d80ac00 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=-1324265472, stack(0xb1015000,0xb1115000)]
0x020ac400 JavaThread "Finalizer" daemon [_thread_blocked, id=-1325322240, stack(0xb0f13000,0xb1013000)]
0x020ab800 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1326379008, stack(0xb0e11000,0xb0f11000)]
Other Threads:
0x020a7800 VMThread [stack: 0xb0d0f000,0xb0e0f000] [id=-1327435776]
0x0d80e800 WatcherThread [stack: 0xb141d000,0xb151d000] [id=-1320038400]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 14336K, used 13414K [0x04810000, 0x05810000, 0x05810000)
eden space 12288K, 92% used [0x04810000, 0x05329a18, 0x05410000)
from space 2048K, 100% used [0x05610000, 0x05810000, 0x05810000)
to space 2048K, 0% used [0x05410000, 0x05410000, 0x05610000)
concurrent mark-sweep generation total 49152K, used 620K [0x05810000, 0x08810000, 0x08810000)
concurrent-mark-sweep perm gen total 12288K, used 12233K [0x08810000, 0x09410000, 0x0c810000)
Virtual Machine Arguments:
JVM Args: -Xbootclasspath/a:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources/LauncherSupport.jar -Dapple.awt.brushMetalLook=true -Dapple.laf.useScreenMenuBar=true -Djavaroot=/Applications/Bome's Midi Translator Pro.app/Contents/Resources/Java
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 7936M, Free = 17592186043905M
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x961f72fa mach_msg_trap + 10
1 libSystem.B.dylib 0x961f7a67 mach_msg + 68
2 com.apple.CoreFoundation 0x956c800f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x956c70f4 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x956c6f21 CFRunLoopRunInMode + 97
5 com.apple.HIToolbox 0x98b8b0fc RunCurrentEventLoopInMode + 392
6 com.apple.HIToolbox 0x98b8aeb1 ReceiveNextEventCommon + 354
7 com.apple.HIToolbox 0x98b8ad36 BlockUntilNextEventMatchingListInMode + 81
8 com.apple.AppKit 0x97980135 _DPSNextEvent + 847
9 com.apple.AppKit 0x9797f976 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
10 com.apple.AppKit 0x97941bef -[NSApplication run] + 821
11 libawt.jnilib 0x0d1cddfa +[AWTStarter startAWT:] + 1706
12 libawt.jnilib 0x0d18b727 -[CPerformer perform] + 243
13 com.apple.Foundation 0x95fa2eac __NSThreadPerformPerform + 705
14 com.apple.CoreFoundation 0x956ca15b __CFRunLoopDoSources0 + 1563
15 com.apple.CoreFoundation 0x956c7c1f __CFRunLoopRun + 1071
16 com.apple.CoreFoundation 0x956c70f4 CFRunLoopRunSpecific + 452
17 com.apple.CoreFoundation 0x956c6f21 CFRunLoopRunInMode + 97
18 ...ple.JavaApplicationLauncher 0x0000758e startupJava(LauncherArgsStruct*) + 342
19 ...ple.JavaApplicationLauncher 0x000068cf launchJavaApplication + 1355
20 JavaApplicationStub 0x00001e8c 0x1000 + 3724
21 JavaApplicationStub 0x00001d0e 0x1000 + 3342
22 JavaApplicationStub 0x00001c35 0x1000 + 3125
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x9621db42 kevent + 10
1 libSystem.B.dylib 0x9621e25c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x9621d719 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x9621d4be _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x9621cf41 _pthread_wqthread + 390
5 libSystem.B.dylib 0x9621cd86 start_wqthread + 30
Thread 2:
2 libclient.dylib 0x0180ef23 JNI_CreateJavaVM_Impl + 57203
3 libclient.dylib 0x0180edab JNI_CreateJavaVM_Impl + 56827
4 libclient.dylib 0x0180e928 JNI_CreateJavaVM_Impl + 55672
5 libclient.dylib 0x0180e4a9 JNI_CreateJavaVM_Impl + 54521
6 libclient.dylib 0x018d6cd8 JVM_Write + 1592
7 libclient.dylib 0x018d67c7 JVM_Write + 295
8 ...ple.JavaApplicationLauncher 0x000084de startJavaApplication + 3726
9 ...ple.JavaApplicationLauncher 0x0000764e runJava(LauncherArgsStruct*) + 78
10 ...ple.JavaApplicationLauncher 0x000075f8 java_main_stub(void*) + 22
11 libSystem.B.dylib 0x96224a19 _pthread_start + 345
12 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 3: Java: Exception Handler Thread
2 libSystem.B.dylib 0x96263048 mach_msg_server + 520
3 libclient.dylib 0x0180fe25 JNI_CreateJavaVM_Impl + 61045
4 libclient.dylib 0x0180fdca JNI_CreateJavaVM_Impl + 60954
5 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
6 libSystem.B.dylib 0x96224a19 _pthread_start + 345
7 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 4: Java: Gang worker#0 (Parallel GC Threads)
5 libclient.dylib 0x0180e588 JNI_CreateJavaVM_Impl + 54744
6 libclient.dylib 0x01824931 jio_vsnprintf + 321
7 libclient.dylib 0x0182486a jio_vsnprintf + 122
8 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
9 libSystem.B.dylib 0x96224a19 _pthread_start + 345
10 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 5: Java: Gang worker#1 (Parallel GC Threads)
Thread 6: Java: Concurrent Mark-Sweep GC Thread
2 libclient.dylib 0x0180f037 JNI_CreateJavaVM_Impl + 57479
3 libclient.dylib 0x0182bbb0 jio_vsnprintf + 29632
4 libclient.dylib 0x0180e9b7 JNI_CreateJavaVM_Impl + 55815
6 libclient.dylib 0x018e8b8c JVM_Available + 29852
7 libclient.dylib 0x0182b992 jio_vsnprintf + 29090
Thread 7: Java: VM Thread
6 libclient.dylib 0x018a3f5b JVM_Lseek + 142763
7 libclient.dylib 0x018a3c8a JVM_Lseek + 142042
Thread 8: Java: Reference Handler
4 libclient.dylib 0x018b8c95 JVM_MonitorWait + 5461
5 libclient.dylib 0x018b7bfe JVM_MonitorWait + 1214
6 libclient.dylib 0x018b787a JVM_MonitorWait + 314
7 ??? 0x0280b839 0 + 41990201
8 ??? 0x02803db1 0 + 41958833
9 ??? 0x02803db1 0 + 41958833
10 ??? 0x028012d3 0 + 41947859
11 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
12 libclient.dylib 0x018a5576 JVM_Lseek + 148422
13 libclient.dylib 0x018b711b JVM_InternString + 2123
14 libclient.dylib 0x018b6f8a JVM_InternString + 1722
15 libclient.dylib 0x018b6d74 JVM_InternString + 1188
16 libclient.dylib 0x018b680f JVM_StartThread + 2175
17 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
18 libSystem.B.dylib 0x96224a19 _pthread_start + 345
19 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 9: Java: Finalizer
9 ??? 0x02803f17 0 + 41959191
10 ??? 0x02803f17 0 + 41959191
11 ??? 0x028012d3 0 + 41947859
12 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
13 libclient.dylib 0x018a5576 JVM_Lseek + 148422
14 libclient.dylib 0x018b711b JVM_InternString + 2123
15 libclient.dylib 0x018b6f8a JVM_InternString + 1722
16 libclient.dylib 0x018b6d74 JVM_InternString + 1188
17 libclient.dylib 0x018b680f JVM_StartThread + 2175
18 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
19 libSystem.B.dylib 0x96224a19 _pthread_start + 345
20 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 10: Java: Surrogate Locker Thread (CMS)
6 libclient.dylib 0x018ce097 JVM_IsPrimitiveClass + 7639
7 libclient.dylib 0x018cdc11 JVM_IsPrimitiveClass + 6481
8 libclient.dylib 0x018b6d74 JVM_InternString + 1188
9 libclient.dylib 0x018b680f JVM_StartThread + 2175
10 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
Thread 11: Java: Signal Dispatcher
0 libSystem.B.dylib 0x961f7336 semaphore_wait_trap + 10
1 libclient.dylib 0x018ceb5e JVM_IsPrimitiveClass + 10398
2 libclient.dylib 0x018ce92e JVM_IsPrimitiveClass + 9838
3 libclient.dylib 0x018b6d74 JVM_InternString + 1188
4 libclient.dylib 0x018b680f JVM_StartThread + 2175
Thread 12: Java: CompilerThread0
6 libclient.dylib 0x018cfec2 JVM_IsPrimitiveClass + 15362
7 libclient.dylib 0x018cfc9b JVM_IsPrimitiveClass + 14811
Thread 13: Java: Low Memory Detector
6 libclient.dylib 0x018d3e32 JVM_IsPrimitiveClass + 31602
7 libclient.dylib 0x018b6d74 JVM_InternString + 1188
8 libclient.dylib 0x018b680f JVM_StartThread + 2175
9 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
10 libSystem.B.dylib 0x96224a19 _pthread_start + 345
11 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 14: Java: VM Periodic Task Thread
3 libclient.dylib 0x018d510d JVM_IsPrimitiveClass + 36429
4 libclient.dylib 0x018d4cb3 JVM_IsPrimitiveClass + 35315
Thread 15: Java: AWT-Shutdown
10 ??? 0x0280428d 0 + 41960077
Thread 16: Java: Java2D Disposer
11 ??? 0x0280428d 0 + 41960077
12 ??? 0x028012d3 0 + 41947859
13 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
14 libclient.dylib 0x018a5576 JVM_Lseek + 148422
15 libclient.dylib 0x018b711b JVM_InternString + 2123
16 libclient.dylib 0x018b6f8a JVM_InternString + 1722
17 libclient.dylib 0x018b6d74 JVM_InternString + 1188
18 libclient.dylib 0x018b680f JVM_StartThread + 2175
19 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
20 libSystem.B.dylib 0x96224a19 _pthread_start + 345
21 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 17 Crashed: Java: AWT-EventQueue-0
0 libmt.so 0x239d9efe Tr::formatString(std::string const&) + 22
1 libmt.so 0x239da00b Tr::TTransMidiAction::GetMidiString() + 23
2 libmt.so 0x23a30eb0 Java_com_bome_mt_jni_TTransMidiAction__1_1getMidiString + 54
3 ??? 0x0280b839 0 + 41990201
4 ??? 0x02803f17 0 + 41959191
5 ??? 0x02803f17 0 + 41959191
6 ??? 0x02803db1 0 + 41958833
7 ??? 0x02803db1 0 + 41958833
8 ??? 0x0280428d 0 + 41960077
10 ??? 0x02803db1 0 + 41958833
11 ??? 0x02803db1 0 + 41958833
12 ??? 0x0280428d 0 + 41960077
13 ??? 0x029014d0 0 + 42996944
14 ??? 0x02803db1 0 + 41958833
15 ??? 0x02803db1 0 + 41958833
16 ??? 0x02803db1 0 + 41958833
17 ??? 0x0280428d 0 + 41960077
18 ??? 0x02803db1 0 + 41958833
19 ??? 0x02803db1 0 + 41958833
20 ??? 0x02803db1 0 + 41958833
21 ??? 0x0280428d 0 + 41960077
22 ??? 0x02803db1 0 + 41958833
23 ??? 0x0280428d 0 + 41960077
24 ??? 0x02803db1 0 + 41958833
25 ??? 0x0280428d 0 + 41960077
26 ??? 0x0280428d 0 + 41960077
27 ??? 0x0280428d 0 + 41960077
28 ??? 0x02803db1 0 + 41958833
29 ??? 0x02803db1 0 + 41958833
30 ??? 0x02803db1 0 + 41958833
31 ??? 0x02803db1 0 + 41958833
32 ??? 0x02991360 0 + 43586400
33 ??? 0x0296bc5c 0 + 43433052
34 ??? 0x02803db1 0 + 41958833
35 ??? 0x02803fdd 0 + 41959389
36 ??? 0x02991344 0 + 43586372
37 ??? 0x02803db1 0 + 41958833
38 ??? 0x02973e60 0 + 43466336
39 ??? 0x02969b70 0 + 43424624
40 ??? 0x02803fdd 0 + 41959389
41 ??? 0x02803db1 0 + 41958833
42 ??? 0x02803db1 0 + 41958833
43 ??? 0x02803db1 0 + 41958833
44 ??? 0x02803db1 0 + 41958833
45 ??? 0x028012d3 0 + 41947859
46 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
47 libclient.dylib 0x018a5576 JVM_Lseek + 148422
48 libclient.dylib 0x018b711b JVM_InternString + 2123
49 libclient.dylib 0x018b6f8a JVM_InternString + 1722
50 libclient.dylib 0x018b6d74 JVM_InternString + 1188
51 libclient.dylib 0x018b680f JVM_StartThread + 2175
52 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
53 libSystem.B.dylib 0x96224a19 _pthread_start + 345
54 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 18: Java: TimerQueue
4 libclient.dylib 0x018b88a8 JVM_MonitorWait + 4456
7 ??? 0x0296b19b 0 + 43430299
9 ??? 0x0280428d 0 + 41960077
Thread 19:
2 com.apple.audio.midi.CoreMIDI 0x23ed3f31 XServerMachPort::ReceiveMessage(int&, void*, int&) + 155
3 com.apple.audio.midi.CoreMIDI 0x23ef28fe MIDIProcess::RunMIDIInThread() + 150
4 com.apple.audio.midi.CoreMIDI 0x23ed5149 XThread::RunHelper(void*) + 17
5 com.apple.audio.midi.CoreMIDI 0x23ed4b16 CAPThread::Entry(CAPThread*) + 96
Thread 20:
0 libSystem.B.dylib 0x961f735a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x96224ea1 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x96253a28 pthread_cond_timedwait_relative_np + 47
3 libmt.so 0x239e4766 bthread_cond_wait(bthread_cond_t*, int) + 112
4 libmt.so 0x23a006fb Tr::TEvent::WaitMs(int) + 27
5 libmt.so 0x23a085c6 Tr::TRuntimeDispatcher::Execute() + 114
6 libmt.so 0x23a00c1f Tr::TThread::run(void*) + 23
7 libSystem.B.dylib 0x96224a19 _pthread_start + 345
8 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 21: Java: Event Monitor Poller
3 libclient.dylib 0x018d4fce JVM_IsPrimitiveClass + 36110
4 libclient.dylib 0x0191a223 JVM_Sleep + 403
5 ??? 0x0290f2d5 0 + 43053781
6 ??? 0x02976728 0 + 43476776
7 ??? 0x02804280 0 + 41960064
8 ??? 0x028012d3 0 + 41947859
9 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
10 libclient.dylib 0x018a5576 JVM_Lseek + 148422
11 libclient.dylib 0x018b711b JVM_InternString + 2123
12 libclient.dylib 0x018b6f8a JVM_InternString + 1722
13 libclient.dylib 0x018b6d74 JVM_InternString + 1188
14 libclient.dylib 0x018b680f JVM_StartThread + 2175
15 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
16 libSystem.B.dylib 0x96224a19 _pthread_start + 345
17 libSystem.B.dylib 0x9622489e thread_start + 34
Thread 22: Java: Engine Callback Poller
Thread 17 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x239d9ef6 ecx: 0x020dbd10 edx: 0x0118081c
edi: 0x020dbd10 esi: 0xb192d198 ebp: 0xb192d158 esp: 0xb192d100
ss: 0x0000001f efl: 0x00010286 eip: 0x239d9efe cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0xfffffff4
Binary Images:
0x1000 - 0x1fff +JavaApplicationStub 1.6.1 (1.6.1) /Applications/Bome's Midi Translator Pro.app/Contents/MacOS/JavaApplicationStub
0x5000 - 0xfff7 com.apple.JavaApplicationLauncher 13.1.0 (13.1.0) <4AC23F10-15F8-A81C-A1A0-89FA16CC14FB> /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher
0x17000 - 0x1eff7 com.apple.JavaVM 13.1.0 (13.1.0) <2842C4EE-869D-81E6-E771-062F583A1044> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x75000 - 0x7dff7 libverify.dylib 1.0 (1.0) <0E0C6835-68C5-A72F-8CA0-77857B632513> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libverify.dylib
0x82000 - 0x89ff7 JavaNativeFoundation ??? (???) <1107BBC2-DFC1-CF1F-44EE-27F7D4349BE6> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x92000 - 0xafff7 libjava.jnilib ??? (???) <C4C57812-6A25-85AB-441B-DE1A71A8DF18> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjava.jnilib
0xcc000 - 0xd8ff7 libzip.jnilib ??? (???) <1317EACC-2494-70C3-4B43-FC9D04579EAF> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libzip.jnilib
0x1800000 - 0x1bf6fe7 libclient.dylib ??? (???) <6B8B4A7E-2844-3AD6-239E-122121D37485> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libclient.dylib
0x1cbb000 - 0x1cbcff7 liblauncher.jnilib ??? (???) <10117357-AD34-E263-4132-902438F8C368> /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/Resources/liblauncher.jnilib
0x1f23000 - 0x1f26fe7 com.apple.java.JavaRuntimeSupport 13.1.0 (13.1.0) <70CFA5B6-4FFA-8EFB-E4CE-202B0B9A4DB6> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
0x1ff4000 - 0x1ff7ff7 liblaf.jnilib ??? (???) <373D235D-3372-814D-DDB5-11C1C750A48B> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/liblaf.jnilib
0xd185000 - 0xd347ff7 libawt.jnilib ??? (???) <FF31ED82-3BB5-A05D-3B83-35E11590E529> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libawt.jnilib
0x224c5000 - 0x224c8ff7 libnio.jnilib ??? (???) <6AE890EE-BB11-6931-EEBF-01AE9D682E3F> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libnio.jnilib
0x226cc000 - 0x2272fff7 libfontmanager.jnilib ??? (???) <78446877-99AA-82F5-8509-0281A5740A47> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libfontmanager.jnilib
0x22f31000 - 0x22f51ff7 libdcpr.jnilib ??? (???) <51F632C6-87F3-5071-9545-896D34C353AB> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libdcpr.jnilib
0x23919000 - 0x2393bff7 libjpeg.jnilib ??? (???) <32233A65-09F0-434C-D616-64946CFEB3C0> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjpeg.jnilib
0x23960000 - 0x2396dff7 libnet.jnilib ??? (???) <E14CEE5F-42DC-9727-6A3E-FE25EAFFB423> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libnet.jnilib
0x239d1000 - 0x23b91ffb +libmt.so ??? (???) <448D98C7-386E-4002-B9AB-7905DA538316> /Applications/Bome's Midi Translator Pro.app/Contents/Resources/Java/libmt.so
0x23ec4000 - 0x23f10fff com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0x9028b000 - 0x90a7a537 com.apple.CoreGraphics 1.543.33 (???) <C57E2964-80AF-6346-6D3E-23AED9D26977> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90a7b000 - 0x90a7bff7 com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x90a7c000 - 0x90a90fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x90a91000 - 0x90ab7fff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x90ab8000 - 0x90abcff7 IOSurface ??? (???) <4B825ADA-8DBE-6BA2-1AB3-307D2C3AFCA8> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x90abd000 - 0x90b76fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x90b77000 - 0x90b79ff7 com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x90b7a000 - 0x90b8cff7 com.apple.MultitouchSupport.framework 204.12.1 (204.12.1) <6BB58E90-21FA-C491-F0E4-54B69CCDBBC0> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x90cd0000 - 0x90ce4ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x90d19000 - 0x90d7dffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x915b2000 - 0x915cefe3 com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9162e000 - 0x916c6fe7 edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9170b000 - 0x9196dff3 com.apple.security 6.1.1 (37594) <1AC07F75-7E27-9662-21DA-B05DFF047B26> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9196e000 - 0x91a1eff3 com.apple.ColorSync 4.6.3 (4.6.3) <68B6A1B9-86CF-0C5A-7D63-56ED4BB2EB5B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91a73000 - 0x91a92fe3 libexpat.1.dylib 7.2.0 (compatibility 7.0.0) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x91b5b000 - 0x91b8cff7 libGLImage.dylib ??? (???) <AF110892-B10A-5B61-F898-21FB2BCE63BF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x91be1000 - 0x91c02fe7 com.apple.opencl 12.1 (12.1) <1BCA4F60-E612-5C1B-EF50-A810D70CDF05> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x91e3b000 - 0x91e4bff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x91e86000 - 0x91e89ff7 libCGXType.A.dylib 543.33.0 (compatibility 64.0.0) <69BE578C-A364-A150-35E3-53EE00F56F05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x92ddc000 - 0x92de0ff7 libGIF.dylib ??? (???) <03880BA1-7A86-0F2B-617A-C66B1D05DD70> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x92de1000 - 0x931f7ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x931f8000 - 0x93233feb libFontRegistry.dylib ??? (???) <F50A60E1-3757-D007-A20D-A5504C17334C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9323c000 - 0x9323cff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9323d000 - 0x9336bfe7 com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9356c000 - 0x93678ff7 libGLProgrammability.dylib ??? (???) <CA0A975B-2BEE-44E7-CFA6-8105CFE6FE00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x93701000 - 0x9377bfef com.apple.audio.CoreAudio 3.2.2 (3.2.2) <1F97B48A-327B-89CC-7C01-3865179716E0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x937a9000 - 0x93ac9feb com.apple.CoreServices.CarbonCore 861.6 (861.6) <D3D5D9F1-01ED-DCAD-6AA9-4ABE60C7A112> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x93aca000 - 0x93b10ff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x93c37000 - 0x93cdfffb com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x93dad000 - 0x93dadff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93dae000 - 0x94115ff7 com.apple.QuartzCore 1.6.1 (227.18) <8A65F233-4C77-BA7C-5DDA-2423F5C1B7A1> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9412f000 - 0x94230fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
0x94247000 - 0x94250ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x94547000 - 0x94597ff7 com.apple.framework.familycontrols 2.0.1 (2010) <50E74916-19A5-F2FC-AB57-76F2C8DDF0A7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x94598000 - 0x945f3ff7 com.apple.framework.IOKit 2.0 (???) <69E4FE93-376C-565E-650F-04FAD213AA24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x94740000 - 0x9474efe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <82B2C254-6F8D-7BEA-4C18-038E90CAE19B> /usr/lib/libz.1.dylib
0x9475a000 - 0x9477afe7 libresolv.9.dylib 40.0.0 (compatibility 1.0.0) <03019DD7-993D-AC88-6636-179F92F315C4> /usr/lib/libresolv.9.dylib
0x9477b000 - 0x9479fff7 libJPEG.dylib ??? (???) <EDA86712-F49C-760C-BE55-9B899A4A5D1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x947a0000 - 0x9484dfe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
0x94858000 - 0x949dafe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <96A45E03-2B29-83EB-0FC6-2C932E398722> /usr/lib/libicucore.A.dylib
0x94a2a000 - 0x94aaafeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x94ad6000 - 0x94b84ff3 com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x94d8c000 - 0x94e69ff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x94f81000 - 0x94febfe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x95025000 - 0x95047fef com.apple.DirectoryService.Framework 3.6 (621.3) <05FFDBDB-F16B-8AC0-DB42-986965FCBD95> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x95089000 - 0x95094ff7 libCSync.A.dylib 543.33.0 (compatibility 64.0.0) <F914F427-98EA-98BC-923D-47274A90D441> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x95095000 - 0x950c6ff3 libTrueTypeScaler.dylib ??? (???) <4C189FCA-A210-7255-8F70-38DF9D19F877> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x950c7000 - 0x95159fe3 com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9515a000 - 0x951a7feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x95306000 - 0x95664fff com.apple.RawCamera.bundle 3.0.1 (523) <BB20C4C8-ACEE-7B40-C1A0-4BF4EC6B8796> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x9568b000 - 0x95804ffb com.apple.CoreFoundation 6.6.1 (550.19) <1E97FB1E-9E42-B8EB-E463-5C75315FDA31> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x95805000 - 0x9580aff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9580b000 - 0x9580eff7 libCoreVMClient.dylib ??? (???) <98CB96B1-85FE-25AF-AB19-ED061912FC3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9580f000 - 0x95816ff3 com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x95817000 - 0x9581dfff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x95a1d000 - 0x95a27fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x95aa1000 - 0x95aa4fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x95f63000 - 0x95f67ff7 libGFXShared.dylib ??? (???) <286F466C-2856-B579-B87F-4E9A35C80263> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x95f68000 - 0x95f75ff7 com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x95f76000 - 0x961e6ffb com.apple.Foundation 6.6.2 (751.21) <DA7A173A-4435-ECD6-F4AF-977D722FD2F7> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x961e7000 - 0x961f5ff7 com.apple.opengl 1.6.7 (1.6.7) <3C529790-DEE9-AC27-A879-806E4C23323C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x961f6000 - 0x9639bfeb libSystem.B.dylib 125.0.1 (compatibility 1.0.0) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
0x96419000 - 0x96425ff7 libkxld.dylib ??? (???) <13F26BB6-C2F7-9D74-933E-09AD8B509ECD> /usr/lib/system/libkxld.dylib
0x96426000 - 0x9643bfff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x965d0000 - 0x965d0ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x965d1000 - 0x9666cff7 com.apple.ApplicationServices.ATS 4.1 (???) <22FCDB9B-B588-D602-3991-26A2E3C51E6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9666d000 - 0x966aeff7 libRIP.A.dylib 543.33.0 (compatibility 64.0.0) <C6E50C7E-EBEE-32AF-FF07-8E325E21A838> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x96781000 - 0x96781ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x96782000 - 0x96782ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x96783000 - 0x967ccfe7 libTIFF.dylib ??? (???) <E45B169E-253E-E865-1501-97777D2702F2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x967cd000 - 0x9680fff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x96810000 - 0x968c6fef libFontParser.dylib ??? (???) <FA6B6B8B-1E3C-8EEB-DD0D-6C7482353179> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x968c7000 - 0x96964fe3 com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9699a000 - 0x96a09ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x96bd0000 - 0x96c21ff7 com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x96c22000 - 0x96c3dff7 libPng.dylib ??? (???) <929FE8EE-277D-F6EB-D672-E6F4CEBF1504> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x96c3e000 - 0x96c73ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <458E819A-4E3F-333E-28CE-671281B318D3> /usr/lib/libcups.2.dylib
0x96c9c000 - 0x96cd9ff7 com.apple.SystemConfiguration 1.10.2 (1.10.2) <830FED9E-3E24-004C-35D5-2C1273F79734> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x96f18000 - 0x96f19ff7 com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x96f1a000 - 0x96f9cffb SecurityFoundation 36840.0.0 (compatibility 1.0.0) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9711d000 - 0x9713bff7 com.apple.CoreVideo 1.6.1 (45.4) <E0DF044D-BF31-42CE-B690-FD1FCE07E64A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x971b1000 - 0x971f4ff7 com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x971f5000 - 0x972e7ff7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.
<7482933B-4AF6-ED55-AD72-4FBD1E134958> /usr/lib/libcrypto.0.9.8.dylib
0x972e8000 - 0x972ebffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x972ec000 - 0x973b6fef com.apple.CoreServices.OSServices 357 (357) <764872C3-AE30-7F54-494D-4BA3CE4F4DFB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x973b7000 - 0x97418fe7 com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x97419000 - 0x974f4fe7 com.apple.DesktopServices 1.5.5 (1.5.5) <ECEDFDF2-C40E-8DF0-F8FC-249CCA762E62> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x97502000 - 0x97937ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x97938000 - 0x98217ff7 com.apple.AppKit 6.6.5 (1038.29) <E76A05A6-27C6-DA02-0961-5C8EEDC5F0A7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x98322000 - 0x9832cffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x9832d000 - 0x9832dff7 com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9848d000 - 0x9848fff7 libRadiance.dylib ??? (???) <9358E1EF-F802-B76E-8E23-2D0695787CFB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x98585000 - 0x98596ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <7A3862F7-3730-8F6E-A5DE-8E2CCEA979EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x98891000 - 0x988d4ff7 libGLU.dylib ??? (???) <CE02968E-930D-E63B-7B21-B87205F8B19A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x988d5000 - 0x988d6ff7 com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x988d7000 - 0x9890aff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x98a12000 - 0x98a2aff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x98a2b000 - 0x98a53ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x98a54000 - 0x98a98fe7 com.apple.Metadata 10.6.3 (507.
<53BB360A-1813-170D-827F-C1863EF15537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x98aac000 - 0x98b55ff7 com.apple.CFNetwork 454.9.4 (454.9.4) <2F8B5BA5-099F-6CDA-F500-4CA188BBCDBC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x98b56000 - 0x98e7afef com.apple.HIToolbox 1.6.2 (???) <F5F99E78-5377-DD54-6138-9FC84467F938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x98e7b000 - 0x98ebfff3 com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x98eea000 - 0x98eeaff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x99352000 - 0x9950eff3 com.apple.ImageIO.framework 3.0.2 (3.0.1) <CB39B067-58B8-70DB-3E40-160604664A6D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x99550000 - 0x9955bff7 libGL.dylib ??? (???) <EAD85409-9036-831B-C378-E50780305DA6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9955c000 - 0x99688fff com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
Model: MacBookPro5,3, BootROM MBP53.00AC.B03, 2 processors, Intel Core 2 Duo, 3.06 GHz, 8 GB, SMC 1.48f2
Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.91.27)
Bluetooth: Version 2.3.1f4, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: ST9500420ASG, 465.76 GB
Serial ATA Device: HL-DT-ST DVDRW GS23N
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24400000
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26500000
USB Device: USB Uno MIDI Interface, 0x0763 (M-Audio), 0x0150, 0x06200000
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06110000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0236, 0x04600000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000
Here is the report:
Report Version: 6
Java information:
Other Threads:
Heap
Thread 2:
Thread 19:
Thread 20:
cr2: 0xfffffff4
Binary Images:
