klausgesing
2010-04-27 00:08:28
Hi there,
It might not be a smart question, but I would like to know if there is a way of determinig the MIDI Channels for an outgoing MIDI Message in the MT.
The background is that I am using a simple sustain pedal that is connected via a midi solutions box which sends a middle C on MIDI channel 2 with a velocity of 127 - and the note that I want to send out the MT would be: NoteOn of Note 38 (D in Octave 2) on Channel 1 Vel 127 - to control a VST Plugin.
Any Ideas?
thanks a lot
Klaus
Any Ideas?
thanks a lot
Klaus
