DJ Urkel Dee
2010-07-02 20:28:36
Hello... I'm new to the world of Bomes and Mac so I really confused.
This is my setup:
Traktor Pro 1.2.6
Numark V7's. (Midi Controller)
Ecler EVO 4 Mixer (Midi Controller)
Kontrol X1 (Midi Controller)
Macbook Pro 15' 2.4 GHz, 2GB Ram
OSX Snow Leopard 10.6.4
Bomes Midi Translator 1.7 Beta
A good friend of mine (Joe Sapo)
Helped me setup everything on my PC but when I tried to transfer the saved template over to the mac these are the error's I'm getting:
Error(015): Error while loading preset '[reset]', Translator 'Reset - All Off':
Incoming Action corrupt or not supported: KAM1
Error(015): Error while loading preset '[reset]', Translator 'Reset - All On':
Error(015): Error while loading preset '[sandbox]', Translator 'manual_flash_timer':
Error(015): Error while loading preset '[sandbox]', Translator 'next_manual':
Error(015): Error while loading preset '[sandbox]', Translator 'prev_manual':
Error(015): Error while loading preset '[tools]', Translator 'Scan - Control Manual':
Error(015): Error while loading preset '[tools]', Translator 'Scan - Init':
Error(015): Error while loading preset '[tools]', Translator 'Scan - Control Auto':
When I go into Traktor setting's and use Bomes as the Midi device nothing works but when I use the Numark V7's as the Midi Controller everything that I directly Mapped to them does:(
Any help would be appreciated!
Thanks In Advance.
This is my setup:
Traktor Pro 1.2.6
Thanks In Advance.
