radiumdaa
2010-07-13 09:35:10
I need the global variable has the value gs=127 but without the need for any input, and will be used as the value of the speed, then be modified,
radiumdaa
2010-07-13 09:35:10
Attigo
2010-07-24 17:46:31
Translator 0: Load Variables
Options: stop=false
Incoming: on activation of this preset
gs=127
Outgoing: (none)
radiumdaa
2010-07-25 17:09:38
Thank , but a have the version 1.5 and this function is not enableAttigo wrote:Hi radiumdaa,
You can set your desired global variables on Preset load, like this:This will set your variable when the active preset loads. You can always edit the properties of selected Presets, and set this one to 'Always Active', so it will definitely activate on start-up and set your variables...Code: Select all
Translator 0: Load Variables Options: stop=false Incoming: on activation of this preset Rules: gs=127 Outgoing: (none)
Hope this helps,
Scott
