Ableton - Load set
the_ungod
2010-07-17 12:32:08
Does anyone knows how to load a ableton live set with MT?
I have a set per song and in a live situation i wanna be able to load different set with using pc...
Attigo
2010-07-24 17:58:21
Hi the_ungod,
This is possible if you are using the latest MT Pro. In the Outgoing Tab of a translator, from the drop-down, select 'Execute File'. From here you can navigate to the file you want to load. You can assign this output to any input from your Controller/Keyboard you want..
Hope this helps!
Scott
