yvon
2010-07-25 02:35:13
Hi, right now I've done a rethink and am able to send keyboard commands CNTL-SHIFT-1, CNTL-SHIFT-2 etc.
I think I mean to avoid using the SWALLOW incoming option and find another way.
when I hold down the shift key note (bottom note on midi keyboard) and then hit the second note on the keyboard that's assigned to send the CNTL-SHIFT-1, CNTL-SHIFT-2 etc. WHILE the shift-key is held. And of course I set them to swallow midi in (note-one).
Thing is I need a way to have the swallowing happen ONLY while the shift-note is held down so that when I lift up the shift note the secondary keys that send the keyboard commands CNTL-SHIFT-1, CNTL-SHIFT-2 etc. DO pass thru the incoming midi notes allowing the keyboard to fundtion normally.
Is this possible?
Is this possible?
