Copy Presets
lqud
2010-08-07 01:05:59
Is it possible to copy presets from one Project into another? I use the OSX beta7 Version. If not, is there another solution to get the Presets from one into anther Project?
2011-02-21 17:13:09
with MT 1.6.2 OSX (and later), you should be able to copy a preset and paste it into another project.
Better to use the menu (Preset|Copy) rather than Command-C.
lqud
2011-03-02 22:11:15
florian wrote:with MT 1.6.2 OSX (and later), you should be able to copy a preset and paste it into another project.
No, sorry it's not possible - It's possible to copy translators, but not presets. In the presets menu is only: ADD, Rename, Delete, Duplicate, Activate, Deactivate, Move, Save as Text file & properties - Or have I missed something?
2011-03-14 13:51:09
oops, sorry, you're absolutely right! Will come in the next version.
