de Haan
2010-08-15 18:56:43
Hi there
I would like to know if anybody knows if I can make this kind of MIDI duplication with Bome's Midi Translator:
My MIDI controller is an Akai APC40. I want to use it for launching audio and video clips in Ableton Live.
So I want to use the pads on the APC40 for launching audio clips in session view AND for launching video clips (locators) in arrangement view.
So when I push one pad on the APC, I want it to launch an audio clip in session view AND to launch a locator at the corresponding video clip in arrangement view.
I am doing this now with MidiPipe. I use the program to duplicate the midi signal from the APC40, so it works with it's native function AND sends midi notes that I can map to the locators.
However, the problem with this setup is that when i push one of the Bank Select buttons to move the red box in Live, the buttons I have mapped to launch locators in arrangement view, does note move on the APC40. So "session view clips" and "locator launchers" does launch from the same pads when I use the Bank Select buttons.
I hope that made sense
Best regards Nikolaj
