fsenseman
2010-09-01 02:58:57
I've got a Fasttrack Ultra 8R that has my midi in/out to pc. I also have an FCB1010 midi foot controller with the Uno chip. It has 2 midi ports IN and OUT/THRU. Merge is available on the THRU. I program the FCB1010 using software on the PC which is much easier than manually doing it with the pedals. I also have a V-AMP Pro. It has midi IN and OUT/THRU with no merge. I like to control it with software on the PC as well. If either is connected alone I have no problems using the software for either. If I chain them together I can't program the FCB1010 unless the VAMP is in THRU mode. If V-AMP is in THRU mode, then I can't program the V-AMP using the supplied software. If I take it out of THRU mode, I still can't program it when the FCB1010 is in the loop. Can Midi Translator PRO assist in a case like this? I am very new to MIDI (not the world though) and I'm overwhelmed with the possibilities. I've also got an AKAI MPK25 with midi IN, OUT and THRU (3 separate jacks) that I can throw in the mix if that would help. I'd really like to be able to just sit and do everything from the computer without changing midi cables in and out.
Kindest Regards and thanks in advance for any help.
Fleet
Fleet
