VJVertex
2010-10-22 11:25:52
first i want to say, MT is a really great programm!
I use it with my Akai APC40 and a Codanova VMX for VJing.
The most things i want working like i want,but there is one thing i need, but i´m not sure if it´s possible.
I need a kind of "shift-function", normaly i press a key on my APC40 and it sends a midi note. Is it possible to create a expression or anything else which change this midi note if i press another key?
example:
pressing key 1 => midi note: C1
pressing key 2 & key 1 => midi note: G1 (when key 2 & 1 is pressed, midi note from key 1 is modified)
it´s similar to the "shift button", pressing "a" = "a" pressing "shift & "a" = "A"
sorry for my bad english, but it´s really difficult to describe what i want.
Hope anybody understand what i need and there is a way to solve the problem.
greets
example:
greets
