mrmorg
2010-11-08 22:06:07
Hi community... this is my first post here.
The Yamaha Tenorion has wonderful new inspireing but somewhat restricted possibilities in termes of note sequencing.
Esspecially the midi features are very weak. Every sequnecer layer is bound to a fixed midi channel and there is no way to vary velocity, octave shift, note leght or midi cc in your sequence over time.
The Tenori-On can only output notes with finxed length and fixed velocities.
Now that I found bome MT the possibillities of breaking these chains seem so be endless and i am really excited to wirte my first translator patches.
My first Idea is to combine the first "score mode" layers (lets say channel 1 to 4) to provide a more complex step-sequencer.
- Layer one provides the note on messages with thire corresponding note values
- Notes values from layer two shall provide an octave shift.
- Notes values from layer three shall canges the velocity
- And notes from layer four dertermine the note length.
All these note values shall be translated to a note sequence outputed on channel on 1.
Ok translating the first three layers into an "note on" message (0x90, note value + octave value, velocity) souldnt be a problem.
But what about the note length. I want to translate the note value from layer four to a timer that syncs to midi clock and timeouts with a certain note lenght.
My plan ist to translate the note value 0x3C which is a C-3 into 1/32 note length. Then Cis-3 should give a 1/16 note langht and so on...
What is the best way to build up such a timer? I read in another thread that there are midi clock pulses provided by midi message 0xF8.
If I would start my timer with the "note on" message from tenorion sequencer layer one and count 3 pulses then this would give me a 1/32 note duration.
If would count 48 pules I would get a quater note, rigth?
Unforunately I didnt find a way to configure the timer dynamicly at runtime. You can only can define fixed timer counting cycles.
So maybe I should define a dedicated timer for every note length I want to have.
