gude2000
2010-12-04 15:41:56
How do you program the expression pedals so that they control volume (exp A) and delay signal (exp B) without having the hexadecimal messages interfere with other messages from other buttons? I have programmed button 6 on the FCB1010 to launch scene 1 ( I see the hexadecimal is F7 00, 54 etc.. when pressed and midi receiving on MT). Interestingly (and annoyingly), when I press the exp A pedal I can see that the patch volume (CC7 on the FCB1010) is controlled by it, but also sweeping the pedals generate THE SAME HEXADECIMAL MESSAGE (F7 00 54, etc...) as button 6, even though they are on different MIDI channels. The effect is that scene 1 is repeatedly launched every time I move either expression pedal!!!
How can I get around this issue?
