RadekPilich
2010-12-29 21:06:44
Hi guys,
I am new to programing BMTE, could you please advice me on how to program this?
1. I want a knob to send narrower values. For example - there is a GAIN knob in application with +/-30dB gain. Lets say I want to use only +/-6dB of that range, more specifically, I want the physical knob on my controller to control that +/-6dB, so that when it is turned to left the gain will be -6dB(as opposed to default -30dB) and when turned to right the gain will be +6dB(as opposed to default +30dB).
2. I want to use ONE knob for both LP a HP filter (2 separate VSTs). I want the left half of the physical knob to operate frequency of the LP filter a the right half of the physical knob to operate frequency of the HP filter.
3. How do I invert knob function? So that when the physical knob is on 0, the virtual is on 127 and vice versa.
Thanks for getting me started!
R.
R.
