somedolphin
2011-01-09 05:09:29
Just found a new bug on Mac when you first open MT and close a Virtual out the CPU goes crazy.
This even happening on a clean file.
Uploaded this screenshot so you can see what I mean.
Thanks again!
Isaac
- screenshot.tiff (286.21 KiB) Viewed 4711 times
2011-01-09 05:32:21
Hi, I cannot reproduce this serious issue. Does it always happen? Even if you close the virtual input ports? Can you find a "minimal" setup to reproduce this CPU takeover?
somedolphin
2011-01-09 06:13:32
Have you tried it with 3 virtual ports?
It seems to only happen if you close the Virtual out when a Virtual in is open.
If you close the corresponding Virtual in the CPU goes back to normal.
This is with a new file and no Midi devices are hooked up.
I just updated to 10.6.6 I don't know if that matters but I haven't seen this problem before today!
Thank again. Isaac
somedolphin
2011-07-01 02:20:14
Great I'll try it thanks!
somedolphin
2011-07-02 01:11:55
It's fix now!
Thank you, take care. Isaac
