Breeze
2011-01-28 07:02:26
It would be really useful to remap velocity and CC values through a map that would match x to y as desired. Apart from obvious things like velocity scaling, key reassignment, and CC reversing, you could also do crazy stuff like using the Mod wheel to stutter volume and create manually controlled LFO-type behaviors, map keyboard to CC or CC offsets, change range behaviors... lots of stuff comes to mind. It would in essence be a 127 value Assignment table with an option to cut values out of the output (for assigning more than one parameter (in two+ translators) to different ranges of a controller, for example). It would also be useful to save and load various maps within the rules section of the translator. I think this feature would open lots of doors.
