Sasch600xt
2011-03-14 03:10:28
Hey all out there
I just got the MT Software. Since 2 days i work with the trial on my PC. i got 98% of my wishlist done....EPIC PIECE OF SOFTWARE!!!!....and for sure the last 2% are the fault of the operator in front of my pc
I am sorry to not use the "search" funktion this time, but i am even not sure which keywords i could use.....
i have one rotary plus the possibility to press the rotary to send a second midi message.
What i try to do is, if the rotary is not pressed down, translation #1 is working and active, translation #2 is disabled. (case 1)
If the rotary button is pressed down translation #2 is working and active, translation #1 is disabled. (case 2)
i use MT to control the light software "ma lighting, OnPc"
one encoder in this software works for UP and DOWN, but also LEFT and RIGHT
What i try to do is to save an rotary by using the switch of the rotary.......released switch means UP and DOWN, pressed switch means LEFT and RIGHT.
incomming midi message of the controller is not the same as outgoing (outgoing is a keyshortcut)
I guess this will be done by "rules"
I would be so happy if somebody could give me an easy example.....dont forget.....i just use MT since 2 days ^^
And hopefully it is possible with MT......but as far i could see....it will be
So long and thank you for your answeres
Sascha
Sascha
