Project file for Korg padKontrol and Ableton Live
transco
2011-04-23 20:18:29
I'm not having much luck setting up the PK as a Midi Input device and Live (Mac) as the target app so I can evaluate the demo version of MT Pro in the 20 minutes allotted. Anyone have a project file (.bmtp) using this hardware / software combination that I could use?
Attigo
2011-04-26 23:54:27
What is the problem?
You need to create INPUT and OUTPUT 'aliases'. Create an input alias called 'From padKontrol' and an outgoing alias called 'To Live'. Any name can do, but you should name them correctly so you can keep on track. Once you have these set out, you should be able to assign the padKontrol controller to the input alias and then assign Bome's Virtual Port 1 to the outgoing alias. Then in Live, select Bome's Virtual Port 1 as the input. You need to create presets to pass through MIDI (unless you have pass-through MIDI checked).
Does this help?
Scott
transco
2011-04-29 19:06:59
Attigo wrote: ... Does this help? Scott
Yes, thank you. I've got the basics going and went ahead and purchased the full version.
Attigo
2011-04-29 22:40:08
Good stuff! Enjoy...
Scott
