califauna
2011-04-28 03:07:40
I have got a Novation Launchpad controller connected to my PC and Im using Miditranslator pro trial.
In the 'set up port alias' config window, there are the midi ins and outs, including Launchpad's MIDI IN and MIDI out.
Setting up a translator, and trying to use the 'capture' box, I am finding that when I go to the Port alias config, and have Launchpad MIDI OUT selected, nothing is captured in the capture box. But when I select Launchpad MIDI IN, instead of MIDI OUT, button presses on the Launchpad are captured.
I am confused about this. I thought that Miditranslator would have to be 'listening'to the midi out of Launchpad in order to capture the button presses, not the Midi In.
Can anyone help me understand this?
XP Pro 32 bit
dual core 2.1 Ghz
Dale.
XP Pro 32 bit
dual core 2.1 Ghz
Dale.
