2011-05-03 11:24:30
A user reported that he could not start Midi Translator 1.6.2 on OS X 10.6 and the error report lists this cause:
Solution:
Apparently, this is not a problem in Midi Translator, but in the Java setup. If you run into this problem, try to update Java on your OS X:
Dyld Error Message:
Symbol not found: _JRSUIGetKey
Referenced from:
/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libawt.jnilib
Expected in:
/System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
- using Software Update (in the Apple menu), or
- by downloading it from e.g. c|net.
