control the highlighted channel in ableton?
in_every_end
2011-05-09 12:04:10
Hi again,
How can I control the volume, mute, solo track controls for the highlighted channel in ableton?
Do I need the output in my translators to be midi or is it something else?
I would also like to be able control the first 8 paramaters of a selected device with the same 8 knobs on my mpd32.
John
Attigo
2011-05-13 00:06:37
Hi John,
What do you mean 'the highlighted channel'? You want 1 set of controls to be switchable between all your channels?
Yes, your translators will need to output MIDI, what else were you planning on using?
As for the 8 knobs, you can use Live's built in 'Macro' knobs, there is some really great tutorials around the web on them...
Scott
