SBurger163
2011-05-11 18:22:49
Hello,
i have tried out the MT 1.6 Classic and the 1.7 Pro trial, but both take no effekt in my software?
The Software to control is "Soniccore Scope Platform". I must send a <ALT+1> to change the screen-presets...
All thinkable solutions are tested, but no response. Midi works perfekt in Ms-editor, I can control everything, but scope --> nothing...
Whats the difference between this softwares ? The last test I´ve done was to check out the Code with Spy++, and theres a diffrence between 1.6 and 1.7... but the new version send exactly the same code as the "native" Keyboard does.
Who can help me ?
Code v. 1.7:
Code v. 1.6:
native Keyboard (works!):
Only the ScanCode is changed, but both don´t work for Scope ?
What´s the way to send a WM_Message instead of a Keystroke?
What Parameters I must set in Outgoing WM_Messages for a <ALT+1> ?
Windowname: Scope Fusion Platform
Class: wxFrameClass
Greetz
Stfean
Who can help me ?
Code v. 1.7:
<00001> 0005012E P WM_SYSKEYDOWN nVirtKey:VK_MENU cRepeat:1 ScanCode:38 fExtended:0 fAltDown:1 fRepeat:0 fUp:0
<00002> 0005012E P WM_SYSKEYDOWN nVirtKey:'1' cRepeat:1 ScanCode:02 fExtended:0 fAltDown:1 fRepeat:0 fUp:0
<00003> 0005012E P WM_SYSCHAR chCharCode:'0031' (49) cRepeat:1 ScanCode:02 fExtended:0 fAltDown:1 fRepeat:0 fUp:0
<00004> 0005012E P WM_KEYUP nVirtKey:VK_MENU cRepeat:1 ScanCode:38 fExtended:0 fAltDown:0 fRepeat:1 fUp:1
<00005> 0005012E P WM_KEYUP nVirtKey:'1' cRepeat:1 ScanCode:02 fExtended:0 fAltDown:0 fRepeat:1 fUp:1
<00001> 0005012E P WM_SYSKEYDOWN nVirtKey:VK_MENU cRepeat:1 ScanCode:00 fExtended:0 fAltDown:1 fRepeat:0 fUp:0
<00004> 0005012E P WM_KEYUP nVirtKey:VK_MENU cRepeat:1 ScanCode:00 fExtended:0 fAltDown:0 fRepeat:1 fUp:1
Class: wxFrameClass
Greetz
Stfean
