Shunyo
2011-06-06 17:07:58
So I'm trying to use the denon midi controller (designed for Traktor) to control some features in Ableton.
The controller has 4 knobs to control the effects section in Traktor and I was wondering if I could use them a bit like the APC40 device control knobs.
The problem I'm having is that they are encoders (sorry if my terminology isn't correct) ie rotating to the left has one value B0 55 7E and to the right
its B0 55 00 and- if I just use the denon as a generic usb device in ableton- for some reason going down (to the left) works ok but if I rotate to the right
it jumps right up (hope this is clear enough). I wanted to use Bomes to somehow translate the encoder-like messages to a more continuous cc-like messages
in order to control effects.
Would like to know if anyone has stumbled upon this type of problem or has any experience with the denon dn-sc2000?
Thanks and sorry if this topic was posted before- just couldn't really find any answers, if you could direct me to the right post would also really appreciate it!
