sideffect8
2011-06-16 00:59:12
Hello,
I am using an aka lpd8 as a serato controller.
The LPD8 has built in functionality to change the midi notes on it's 8-pad interface, as well as functionality for program changes through the the pads.
However, both note-switching and program changing affects all 8 pads at once. I'd like to change the notes of only 4-pads at a time. And, i'd like to use 2 of the knobs to scroll through note banks, (so 1 knob to change the presets of the first row of pads, the 2nd knob to change the presets of the second row of pads).
My questions:
Can you toggle the program change for only a select group of pads, (instead of changing the program globally)?
Or, if i wanted to change the midi notes for only a select group of pads, is there a way to group the notes, reference them as presets or banks, and then toggle those banks on / off?
make sense?
Any help is much appreciated.
My questions:
make sense?
